Brake Lights not working but fuse not blown under dash
What year is your car?
On my 94, there is a brake light switch on the brake pedal assembly.
There is a brake light fuse in the passenger side fuse block which is under the right side dash.
There is a brake light relay in the left rear trunk panel. The relay is blue and is above the ABS module.
Hope that helps.
Cheers,
Allan
Hope that helps.
Cheers,
Allan
