Brake lights not working XJS
My two main brake lights stopped working, but the middle one on top of the trunk is still operational. Turn signal and running lights work fine. I also noticed that the hazard lights do not come on when I push the button, don’t know if that’s related. Any help would be greatly appreciated thank you.
- Scott
1992 XJS V12
- Scott
1992 XJS V12
Here's the diagram. Nothing common between the hazard flasher and the brake lights. Looks like the only common thing for the brake lights is the bulb failure unit.
Or you can try and either bypass, or build a custom bulb failure sensor.
coastaljag98
10-15-2012 10:19 PM
