Brake Master Cylinder
Received 10,905 Likes
You can buy a new accumulator for $100 or so. There's a GM part number floating around out there somewhere.
Not sure about rebuilding the master cylinder...which I think is called an "actuator" in Teves ABS terminology.
If nobody here chimes in with an answer Google "Teves ABS rebuilding" and see what happens
Thank you to Doug for your help, I still have not found any one that sells a repair kit or will repair abs actuators. I have found a place that will sell me a new brake actuator for $2600.00 I paid less than that for the car which is very nice condition except for the actuator aka (master cylinder) any ideas?. I think the cost of a replacement is a crime.
There are companies that rebuild ABS modules. Not sure they go back to those old school systems but a search for ABS module rebuild bring up a few hits. Maybe contact some of them for ideas. Also GM used the same system on it's 80s vehicles.
The other alternative is to install a standard braking system and eliminate the ABS system. The early systems are pretty primitive and do not work that well anyway.
Back in the day the old Teves design was also found on about a ka-billion Jeeps....and most of them were recalled for various ABS problems. I've long forgotten all the details but I'm pretty sure that most of the issues came down to contamination. That is, the system simply won't tolerate dirt....and Americans traditionally never flushed brake fluid.
Only relatively recently has the wisdom of periodic brake fluid flushing caught on in the USA. For decades it was never listed as a recommended routine service by USA manufacturers (and perhaps still isn't) and the mere suggestion of it usually evoked a "You've gotta be kidding" response from the general public.
orangeblossom (12-17-2014)
The system is extremely sensitive to dirt, and if you just push bach the pads when renewing you effectively push contaminated fluid back into the actuator. Hence the Jag manual stating that the bleeding screws should be opened when pushing the pistons back. I believe you have the "all in one" master cyl + ABS actuator that is part of the Mk II Teves system. (Changeover mid '93 for the XJS IIRC.) A number of Buick 89 - 90 models used the same system, the years once again IIRC. Google and check your local breakers for the part. As the brake setup may be slightly different (cyl dia and brake balance) it may not be a perfect fit.
Is it possible to remove the accumulator sphere safely (I think that they are pressurized to about 84 bar when new but gradually lose pressure over time).
Mine seems to take a long time now for the ABS warning light to go out but I have the chance of a second hand sphere from a breaker.
Steve
Steve
With engine switched off press the brake pedal repeatedly until the pedal goes hard. If the accumulator is dying it doesn't take more than a press or two. If it takes more than ten I wouldn't bother changing it yet. Remember to have a cloth underneath the accfu when removing to catch any spilled brake fluid. In case of spills immediately clean off with lots of water.
My name is Graham, I just want to thank you all for your helpful inputs. I did install a GM acumulator, this helped pedal pressure. My #1 problem is while waiting at a light the pedal drops to the floor. I suspect the brake actuator aka master cylinder. I want the car to be safe, my options are buy master cylinder $2600.00 Not going that route. option two convert the car to standard brake system. My problem is where to start, does anyone know of a member who has done this? any information appreciated. Does anyone know if whether the teves actuator can be taken apart? I dont want to take it off unless I can look inside it , or if I could find a rebuild kit for just the actuator cylinder seals? Regards Graham
1991 Jaguar xjs v12 abs brakes.
convertible classic collectio
63000 miles
63000 miles
I found the cause of the pedal drop on my xjs, it has a a leak from the rear of the brake actuator aka master cylinder. I am calling a few salvage yards to try find a good replacment, I will keep you informed. Thank you to everyone for your information and ideas. I will get this cat back on the road. Regards Graham
I found that Cardone sells rebuilt units. Part number 12-4418. Advance Auto shows it at $814.49 and you can get 15% off using coupon code OCB5.
Prior remanufacturing appears to reman the Teves mark II hydraulic units. However they do not list Jaguar in the menu. I would call them. maybe you can send your to them for rebuilding.
Also a Google search turns up SIA Electronics as a rebuilder. However their website shows only electronics but a Ford forum describes a process for sending the unit in to SIA. A phone call might be in order.
The Teves Mark II system was a very popular system so someone will fix these.
Update, my Jaguar xjs is back on the road ....with brakes that stop! I found a car salvage place in England, they had a right hand drive abs master cylinder, $280.00. I recieved it last week, removed the piston assembly from it and installed it in my left hand master cylinder, bleed the brakes, works Great! thanks again for all your help Graham
grajaguar (11-08-2012)
Hello all, I am new to the forum so forgive me if I am posting in the wrong location. I have an 84 Jaguar VDP and I am noticing a leak in the master cylinder. Whenever I am idled for to long a a stop light the brakes go down a couple inches and the car begins to roll. The only place I see that might be leaking is the resevoir cap. Could this be right? I have seen the caps on ebay for about 50 bucks, but I am not sure if the cap should be replaced or just needs a new washer/o ring? What's your thoughts?
Jagxjs (01-14-2013)
