Brake problem?
Old 08-06-2020 | 04:41 PM
petemohr's Avatar
Default Brake problem?
On my '93 Coupe, I had a slight shimmy in the steering wheel when applying the brakes. The brakes were pretty old so I replaced the rotors, calipers, and pads (EBC) but I still have the same problem. If anything it's a bit worse. It occurs on light to moderate braking. It doesn't pull left or right. Just has a shake in the steering wheel. Can something in the ABS be causing the problem? Any idea what else could cause this?.
Old 08-06-2020 | 08:45 PM
VancouverXJ6's Avatar
Subframe mounts, alignment. Etc? Jack up the car under the frame and give everything a shake, youll be able to hear/see any wheel bearing issue and note abnormal tire wear.
I've had all those issues cause shaking etc (how ever you describe it in various degrees.
Old 08-07-2020 | 08:55 AM
petemohr's Avatar
Tried pulling and shaking. Didn't see anything obvious.
Guess I need to bring it to a front end shop.
Old 08-07-2020 | 09:52 PM
orangeblossom's Avatar
Hi Petemohr
Maybe its something simple like your front wheels need re-balancing
Old 08-08-2020 | 06:23 AM
jal1234's Avatar
You need to check the run-out of the brake rotors with a dial indicator. Measure on the face of the rotor, about 1/2" in from the outer edge of the rotor. You should have no more than .002" run-out when you rotate the rotor thru 360°; this figure is good for most cars. If you do, take the rotors off the hubs and clean both mating surfaces thoroughly of any rust. Check the run-out of the hub itself in a similar manner. Given the smaller diameter of the hub, any run-out at all there will be magnified at the larger diameter of the rotor. Reassemble, and recheck run-out. If you still have excessive run-out, you probably have a bad rotor.
On another car I have, I found the hub was bad with lots of run-out. I changed it out and the shake went away.
Old 08-08-2020 | 06:35 AM
petemohr's Avatar
Thanks for the replys. I'm now thinking it's something in the steering and/or front suspension. It's not speed dependent and the amount of shimmy varies. It is minimal when braking in a straight line but gets much worse when breaking on a curve. It's not acting like an unbalanced tire or bad rotor.
Jet4me2fly
07-04-2018 12:35 PM
Tink
08-31-2016 07:41 PM
pdog2000
11-16-2010 09:08 AM
Louenigma
09-08-2008 03:22 PM
Louenigma
09-07-2008 07:36 AM
Quick Reply: Brake problem?
