Brake Reservoir Hose Replacement
On the early XJS cars, the remote brake fluid reservoir feeds the master cylinder via 2 rubber lines.
Now, any time I ask the old parts guys, they instruct me on how I can't use hose for brake fluid, you can't repair that with that, etc. After I've explained why I need it, they never have a safe answer; it's always a guess.
Age is not kind to rubber, so they need to be replaced. What have you used to replace those two lines? I would have to think a neoprene hose would suffice? Or something like fuel injection or power steering cooler hose?
EPDM rubber is the right stuff to resist brake fluid in the feed from the reservoir to the master cylinder: eg
6mm ID 1/4 EPDM Smooth Rubber Tubing Coolant Radiator Hose Brake Fluid Tube Pipe | eBay
Greg
Greg
I got the correct elbow from growler parts
GROWLER PARTS - XJS
quite reasonable priced some of their parts
GROWLER PARTS - XJS
Greg in France (07-25-2015)
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
