Brakes - Clicking sound???
Hello all! I have a 1994 XJS V12 with 40,000 miles now. Recently and only while in Park, I hear and can feel around the shifter a CLICK when I depress the brake pedal. This CLICK does not occur with the shifter in any other position. No warning lights, no apparent braking issues, front brakes have been redone, rears are good. There must be some type of relay under there. If so, what is it doing (or not doing)?
Kelly
ktrumper
1994 XJS V12
Kelly
ktrumper
1994 XJS V12
Kelly
ktrumper
1994 XJS V12
Kelly
ktrumper
1994 XJS V12
ktrumper (10-25-2012)
That could be your neutral safety switch. When you put your foot on the brake pedal, a solenoid opens inside the shifter console to allow you to shift the car out of Park. That solenoid makes a click when it operates. That whole setup is there so you can't accidentally take the car out of park, start it while in gear, etc.
If it's inside the shifter then my vote goes for the gearshift interlock solenoid that stops you moving out of neutral without your foot on the brake.
The XJ40's have a habit of getting noisy but it's usually slight wear or adjustment in the shifter mechanism on those rather than a sign of impending solenoid failure. XJS is likely to be similar cause.
