Brakes hitting the floor
Then turn the ignition ON wait till the pump stops then pump the pedal again several times this will prime the system and the reservoir level should drop.
Go straight to 3,4,5, and 6 Pump pedal until pump stops - This procedure primes the ABS.
Then bleed brakes.
Andrew Fanshawe
09-14-2015 07:40 PM
