Brembo rotors question
I purchased a set of front Brembo rotors from a guy off another Jaguar forum that was going to use them in a full brake rebuild and never got around to it. They're part # JLM776. I'm trying to find Brembo rotors to purchase for the rear as well since I'm sort of OCD about that kind of thing and I keep finding a ton of different part #s and all this stuff and I'm kind of overwhelmed since I'm having to try and order other parts too. Are all the Brembo rotors the same, just using different part #s for some reason or another? Surely Brembo only has 1 casting for rear inboard rotors and 1 casting for rear outboard rotors so obviously I need to pay attention when I place the order, but I just keep seeing so much that seems to conflict so I just wanted to check, maybe someone on here has purchased Brembo rotors before and can clarify with a correct # to order or some information.
Received 10,920 Likes
"JLM776" is a Jaguar part number, not Brembo.
Often the factory part number is used by sellers even if the part is non-factory, for clarity in what the part is supposed to fit and for search purposes.
Anyhow.....
I'm not an expert on Brembo's entire product lineup but I know they make lots of brake rotors, from exotic high performance stuff to to ordinary, standard specification replacements. I suspect you've been sold the latter. I'm not sure what various choices they might offer for our older Jags. They probably have an online catalog that would tell us.
They a known, quality name brand
Anyhow.....
08Z06
12-07-2010 09:23 AM
jag_genius
10-01-2009 12:11 PM
jag_genius
12-03-2007 06:32 PM
