Broken Hood Release Cable FAQ RESOLVED
Old 04-17-2014, 07:53 AM
cybercg's Avatar
Default Flared Hood Latch Pins
Just a thought to interject on the flaring of the hood latch pins. I am not a mechanical engineer, but it occurred to me that during a collision, the hood could begin to fold like Greg suggested. If the hood pins are not flared, the aft end (windshield end) of the hood could pull itself free from the latches and become a serious hazard to the occupants. Think guillotine. I plan to keep my flares.
Old 07-19-2014, 07:42 PM
hank's Avatar
This happened to my 92 three years ago. The hood [oops! "bonnet"] will only open about an inch before the safety latch catches it. After many fruitless attempts and some skinned knuckles, I took a half day off from work and drove slowly, with a careful eye on the opening and safety latch, to the nearest dealer almost an hour away.
Then I read magazines and used their wifi to mess around, and in just over two hours the car was returned to me, everything working right, and freshly washed and dried. The cost was less than $100, and was very worth it.
They didn't volunteer, and I have no idea, how it was accomplished. But standing on my head down under the dash with a flashlight, poking and prodding, only frustrated me. The sad thing is, I already had the new cable, just couldn't get it to go the right way.
My 92 has a short cable from the lever to the left catch, then a second cable connecting to the right catch. So far, the left-to-right cable is still original. [fingers crossed!] Didn't know there were two when I bought the one.
Old 01-16-2015, 05:00 PM
afterburner1's Avatar
Instead of a cable, I used a bicycle spoke. Easy installation, adjustable, and almost break proof (Idea from XJS Forum)
Old 01-16-2015, 09:04 PM
RagJag's Avatar
I did grind the pin flare off mine. I can see no safety factor involving the bonnet beheading me in case of a collision. I don't ram things with my cars anyway. If I were younger and expected to live many more years, I might be more cautious. I makes me smile that so many of you think Jaguar had a good reason to flare the pins. This is, after all the guys that put the park brake handle on the left of the drivers leg for LHD cars. Where is it for RHD cars? Cheers, RagJag
Old 01-02-2023, 07:31 PM
curtsjaguar's Avatar
Default Broken Hood Release New Option - Camera Scope & 55" 3/4 Socket Extension
Originally Posted by cybercg
I need some advice. The hood release cable has broken about a foot into the cable sheath that runs from the interior release handle to under the hood (1995 XJS). That means that there is still cable, possibly, inside the sheath between the driver side under hood latch and the interior cabin. Does the sheath run through the driver side fender well on it way to the latch? If it does, I might be able to get a hold on the cable there and open the hood. Any ideas on how to get the hood open so I can replace the cable? All suggestions are welcome. Thanks.
Cybercg posted this back in 2012 and it was really helpful as I tried to fix my broken bonnet cable. I got so much bad advice about how this was impossible and I'd need to cut a hole in my car. Don't believe it. I used the above thread from Cybercg to start and then I added some additional technology to find and remove the bolts. It's actually fairly easy to do.
The process I followed was:
  1. Removed the grill and front hood hinge bolts.
  2. Pulled the hood forward (don't worry about the hood struts, leave them attached).
  3. Lifted the hoof up about 4-5" and supported it with a 24" piece of 2X4 wood running from the grill toward the windshield about 10"-12" inboard from the hood edges.
  4. Removed two bolts on the drivers side hood latch that secures it to a mount bracket. I used a 30" AND a 24" 3/4 socket extension together (I purchased these:
    Amazon Amazon
    ) . The socket needed for the bolt is a metric 8MM.
  5. The extensions together look silly, but allow you to work from the front of the car (front of the hood) without skinning your knuckles.
  6. Since I did it by myself I needed to find a way to "see" under the hood. Back in 2012 this option didn't exist for Cybercg, but I purchased a mini scope lighted camera attached to my cellphone to find the bolts under the hood and better use the long socket. (This is the one I used
    Amazon Amazon
  7. You should only have to unbolt the drivers side to release the hood.
  8. Now that the hood was open I bolted the hood latch back in place.
  9. I replaced the hood release cable with a new one from SNG Barratt part number: HHC2540AA and lubricated everything and tested for proper release.
  10. As Cybercg advised, I realigned the hood for proper clearances at the windshield cowl and both fenders.
    1. This is the long socket extension
      Needed the camera to see the bolts back here when the hood was down.
      The latch unbolted and everything released!
      This is the camera with lights on the end. It was very helpful when trying to do this. It gave me eyes under the hood.
      The hood latch has 2 - 8 MM bolts you'll need to remove.
      Camera was fed forward to this position so I could see and illuminate the area and it helped me to attach the long socket on the bolts.
The following 3 users liked this post by curtsjaguar:
Greg in France (01-03-2023), paddyx350 (01-10-2023), ptjs1 (01-03-2023)
RaceDiagnostics
07-07-2022 06:41 AM
dude1579
08-12-2019 06:29 AM
SeanU
09-18-2015 08:09 AM
Lawrence
XJ40 ( XJ81 )
09-18-2015 02:03 AM
SeanU
09-14-2015 04:31 PM
Quick Reply: Broken Hood Release Cable FAQ RESOLVED
