A/C Blower motor speed?
Hi gang,
my A/C blower motor works on speed 1 and speed 2, however when switched to high speed,
there is no increase in blower motor speed. I have verified that both blowers are working.
Is there a relay for just the high speed setting?
Any and all suggestions are welcome.
1995 XJS conv.
Thanks!
1995 XJS conv.
Thanks!
Hi Ted,
I'm assuming you have a V12, having looked at the diagram there is a relay in both blower units which is fed from the climate control module, so as they are working on 1 and 2, the problem is not there.
The mode switch drives into the climate control module as well as the control panel module.
So, your problem could be with the mode switch, the wiring between the switch and modules or one of the modules.
Personally, I would start with the switch and go from there.
As far as I can see, there is no separate fuses or relays for the high speed setting.
Check out this site for a free drawing of your car Jaguar parts and Land rover parts new used and remanufactured
Hope this helps you,
As Jim suggested, start with the switch. You are looking for a 4v output on pin 5 of the connector when 'high' is selected. If not you should pull the switch and test it.
If you have 4v there, then check the top connector of the CCECU. You should have 4v on Pin 15. If you don't then the problem is in the wiring between the two connectors.
Make sure you inspect the connectors and clean them if necessary.
Also, out of interest, if you turn the fan selector to 'Defrost' do you hear an increase in blower motor speed? There is a separate high speed relay in the system, you can check pin 1 of the central connector on the CCECU. There should be 10v when 'high' is selected.
Cheers,
Allan
Cheers,
Allan
Cheers,
Allan
Let us know how you get on.
Cheers,
Allan
OkieTim
09-08-2015 04:48 PM
