A/C blowing warm
I know about AC in general, but am not familiar with the system on your 95 car. Do you know if it is a TXV system or orifice tube? In general, the static pressure, engine off, should be close to temperature in degrees F. When running with compressor on, the high side should be roughly 2-3 times outside temperature, low side should be 30-45 psi. if you are 45 low side and it is not cool to cold, are you sure the temperature door is going to cold, can you set it to hot and have it blow hot?
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
