A/C charging
Old 03-19-2016, 07:19 PM
Vee's Avatar
Vee
Vee is offline
Received 1,563 Likes on 1,214 Posts
Whoa. PAG46? I could never find a requirement, so I used the most common PAG150. How can I figure out which oil is needed for my 96 XJS?
Safari (05-25-2016)
Old 03-20-2016, 12:59 PM
macdoesit's Avatar
Banned
It is a one man job to get the dash and console out. It is a two man job to get the aircon unit out as it weights about 40 kilos and needs someone each side to remove it without wrecking wiring, vac tubes etc etc. If you do get to it, post beforehand and I'll try to write up what I did. A video of what you have to do would be a terrific resource for the forum. the big thing is to label each side of all the loom plugs you undo, and take VERY many very detailed and careful shots of exactly where the two huge fat looms that go over the top of the unit are placed. There is only just room for them between the dash and the unit and the instrument binnacle.
This is what you need for the pozi bits: Milwaukee 1" 25mm PZ2 50 Screwdriver Bits Pozi 2 Drill Shockwave Impact Duty | eBay
Short ones. All the cross headed screws on the XJS are pozis.
Greg
Do I have to take aircon out if it is just a loose hose nut ?
Old 03-20-2016, 02:26 PM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
If you mean a loose nut holding the big return hose onto the evaporator pipe that pokes through the bulkhead, no. But you do need to replace the little O ring in that joint and then do up the nuts carefully and not too tight, just enough. It is this operation that must be done with a spanner on each nut, the one on the hose and the one of the evaporator fitting so there is no strain on the evaporator pipe.
The aircon unit's evaporator is a one piece effort with nuts and other fittings somehow fixed on the copper feed and return tubes of the evaporator matrix itself. It is these nuts you have to support while doing or undoing the hose and valve connections on the engine side of the bulkhead, or the tubes twist and fracture. If these tubes are fractured you have no choice but to remove the aicon unit to get at them.
This is the sort of thing it looks like (I an NOT saying this particular one is correct for your vehicle):
Jaguar XJ Series 3, XJS Air Conditioning Evaporator (AEU1191-A) - JustJagsUK.com=
There are much cheaper ones on ebay.com which say they fit, but whether they do or not I have no idea, but maybe if you know an aircon guy they can be made to fit/work with a bit of braising etc etc and a load of money saved. A second hand unit is Ok as long as you give it a thorough test that it will hold pressure for several days before you fit it.
Greg
macdoesit (03-21-2016)
Old 03-20-2016, 03:49 PM
JayCee's Avatar
Mine is written on the plate on the side of the compressor. Also, you can google PAG oil and several websites have lists of compressor brands/types and their oil requirements.
...Jimmy
Old 03-20-2016, 08:24 PM
JTsmks's Avatar
http://www.aa1car.com/library/pagoil.htm Super good a/c reference chart here........http://www.johnsens.com/uploads/file...cantguide4.pdf
My 86 XJS w/ Harrison takes PAG 150 with its r134 conversion
My 97 XJ6L with Denso unit takes PAG46. I've put compressors and vac'd/ serviced both cars. I try to stick with the recommended PAG requirements.
Greg in France (05-26-2016)
Old 03-21-2016, 02:15 PM
macdoesit's Avatar
Banned
Greg
It will be 5 to 6 weeks before I attempt the AC repair. I want to thank you for all the info and when I start the project I'm sure I will have more questions.
Thanks again
Greg in France (03-22-2016)
Old 05-25-2016, 01:50 PM
Vee's Avatar
Vee
Vee is offline
Sorry to restart an old thread, but the PAG150 oil I used when working on my AC system was used based off of this website:
Jaguar Refrigerant and oil capacity charts || TechChoice Parts
It was found on the internet, so I didn't consider that it could have been wrong.
  #28
Old 05-25-2016, 10:35 PM
daverb's Avatar
Old 07-29-2023, 10:15 PM
Xeno's Avatar
You'll also need some PAG150 oil.
But how much oil? The 2004-2007 X350 is supposed to have 6.1 oz of oil in the AC system. The compressor holds about 3 oz of oil, I hear. Does the rest of the oil evaporate under vacuum? Should you add 3 oz of oil if you vacuum down the AC and recharge it? What if you're just recharging it without flushing it out first?
I've got a used 2004 XJ8 with 100K miles that may never have had its refrigerant changed. The AC isn't the least bit cold. The refrigerant low port reads 0 PSIG (it's just at atmospheric pressure); the hi port reads 50 PSIG. I want to just blow in some more R134a without flushing it, but I suspect a lot of oil has leaked out.
Also, Jaguar manuals call for PAG 46, not PAG 150. Are they compatible?
  #30
Old 07-29-2023, 10:19 PM
Vee's Avatar
Vee
Vee is offline
you’re in the wrong forum. This one is for the XJS models. Way before your x350
  #31
Old 07-29-2023, 11:55 PM
Xeno's Avatar
Sorry. I don't know how I jumped forums.
Vee
09-07-2020 01:16 PM
Mac Allan
06-04-2020 08:58 AM
gavinm
07-28-2017 05:38 PM
disguay
11-23-2012 01:10 AM
maikal_0011
05-27-2012 08:19 AM
Quick Reply: A/C charging
