A/C/ condenser fan motor
There is a bit of information missing. What is the model and year of the Jaguar you are working on? Are you actually looking for a condensor fan or is it the evaporator fan?
Condensor fan is mounted on the front of the engine unless it has electric fans ( again year makes a difference). Is the fan under the dash if so that is the evaporator fan ( again year makes a difference).
Get back to us with the info and we will try to help.
Thanks so much for responding. I have a 1994 XJS 4.0 convertible. There are two fans in the front. One is in front of the engine itself and the other is an electric fan in front of the condenser on the passenger side of the car. Those fans are almost side by side. The electric motor appears to be laboring to run and my mechanic believes the fan is not turning fast enough.
Larry
Larry
Received 10,871 Likes
Google "CBC6685 Jaguar" and see what comes up
Here's one:
https://www.ebay.com/itm/JAGUAR-OEM-...-/152686453381
Probably some used ones out there, too.
Try David at:
Everyday XJ
Here's one:
Try David at:
Everyday XJ
Sherman1952 (08-29-2018)
Right.
CBC6685
https://www.jaguarclassicparts.com/u...otor-4-0-litre
The aux fan is known as an engine cooling fan; it really isn't intended purely as an a/c condenser fan....although it does serve that function as well
Spikepaga
08-13-2017 09:26 PM
bsprowls
01-20-2012 09:26 PM
