cam cover gasket sealant
hello everyone, finally started the cam cover gasket and half moon replacement. Was wondering if I needed to use a gasket maker/sealant on the cam covers and half moons. The cam cover gaskets I order I believe are the Gortex ones, looks like a piece of thin sandwiched between two rubbery pieces, and using the alum half moons. Also thought I read somewhere to use new cam cover bolts?
Received 10,920 Likes
The cam cover, was supposed to be my winter project but it's just too cold in the garage to get anything done so far. But I have been reading up on it in preparation. On page 62 of "the book", Kirby talks all about the cover bolts. However, Doug has the real experience, all I've done is read about it.
Question for Doug though (if you don't mind a bit of a hijack). Did you have to go in afterwards and re-tighten the bolts, or did you use some kind of locking washers or Loctite?
Bill C (03-19-2014)
Dickie_L_J_O
09-13-2015 07:44 AM
jagent
09-12-2015 09:10 AM
1964Daimler
09-09-2015 11:20 AM
