im trying to dial in -1-2* of camber in the front and rear of my XJS
ive scoured google looking to figure this out and ive come up with nothing useful.
i dont even understand how the rear hubs remain veritcle since theyre only bolted at the bottom.
i plan on going a bit lower than my current height and the wheels ive got just barely tuck in as it is. ive got a hair of rub going over rough potholes.
Shims are used to adjust the camber on both the front and rear. It's detailed in the Jaguar workshop manual.
The front is done by shims on the pivot bolts. The rear is done by shims on the inner axle before the brake discs (on a pre-facelift).
Make sure you're read the manual properly as it's easy for people to screw up the castor on the front if you don't understand how to set up the camber shims. Don't let a garage do it if they don't fully understand XJSs.
The warning about shops screwing front suspensions on Jags is REAL.
The camber shims on the top inner pivot bolt MUST be the same thickness on the front bolt as the rear bolt. This keeps the top bolt AND the lower bolt parrallel. The Caster is done seperately with shim movement at the actual top balljoint.
Those that try and do the caster/camber adjustment as a one hit adjustment, end up chopping out suspension pivot bushes very quickly.
As Doug said, the rear camber is shims removed from the Rotor to Halfshaft area only. The shims INSIDE the rotor are to centralise the rotor in the fixed position brake caliper, so dont mess with them lightheartedly.
The hub stays vertical coz the top arm IS the actual driveshaft, and is a unique design.
Castor is the way to cure steering pull providing everything else is in tip top condition. Castor is the final adjustment really. It's the final tweak to get your XJS going in a straight line.
However this should only be done on a dead flat smooth road. Of which not many exist !
