Camshaft Oil Feed - again ...
I know this has been discussed but I haven't found a definitive answer for the torque requirements of the camshaft oil feed banjo bolts.
I have replaced mine with longer ones and thicker copper sealing washers - bank A I could probably have opened with fingers, wasn't tight at all.
Anyhow I have the new ones in but they're just snugged up - came to look for a torque setting in the repair manual - since I'm posting here you can guess how successful that was.
I've read a few posts about these things and 'just snug enough' with my luck is letting Murphy into the room - if something simple and stupid can mess up my day it absolutely will (would be the year in this case if they strip out).
Does anyone have the official Jaguar numbers for these things ?
Ben
I have just consulted the Jaguar Repair Operation Manual. NO torque figures are given for this operation, not even in the detailed description of how to do it, nor in the Torque spec section.
I reckon 15 ft llbs would be plenty, with no real chnace of thread striping with your longer bolts, and I would use some Loctite too. If possible, maybe weld up a convoluted-lever special tool that in extremis you could use, engine in the car, to nip them up? See where the flats of the bolt are and make the tool so you know you can engage it? It is the A bank ne that is the problem, engine in car.
BenKenobi (07-13-2022)
The following 2 users liked this post by ptjs1:
BenKenobi (07-13-2022),
Greg in France (07-14-2022)
The following 3 users liked this post by jal1234:
The whole page also has the oil cooler on it. I only copied the part with the cam oil feed banjos. Note that there are two different specs, depending on whether its the banjo on the side of the block/oil pressure sender pedestal, or the cam feed banjos.
The following 2 users liked this post by jal1234:
Greg in France (07-15-2022),
ptjs1 (07-14-2022)
innovant
04-29-2021 03:02 PM
