Carpet soundproofing
If you can afford it, dynamat everywhere you can. Then put the OEM stuff on top. I have been in an XJS wwith this done and boy is it Q U I E T.
But, on the floorpans I would ensure you have painted on Rustbullet or PoR15 -type stuff before you glue anything down. The floorpans mainly rust from the inside out owning to damp carpets, water on shoes, etc etc. These coating effectively mean the water never gets to the steel.
Flint Ironstag (02-27-2020)
Greg in France (02-26-2020)
Hello Brinny
I went with Chinese soundproofing over dynamat, mainly due to price. For the floor pans - instead of gluing the mats to the car - I glued them to the underlay of the carpet. That way I can remove them easily when needed. (As I have done on numerous occasions)
Steve
Steve
This is what I saw
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20190727_154206_062b517a19c6df8f4540e7a5493ace8db9a7fc47.jpg)
Hello Brinny
Along the door sils I have installed the mats - but have cut in access holes that will allow me to place the wax oil wand in there for yearly preservation services. Same for the boot area, so i can get the structural members oiled up, and along the area between the boot and rear bumper (where mine was really bad).
For the sils in front and behind the rear tires - I have left gap between the wall and the floor (so to speak) as this will still be a catch point for moisture and I think if you try to mat the base of these areas- you would just make it worse. I also have (or will have) access to put the wand in these area for the 12 month wax oil application
Steve
Steve
It DID NOT feel like a science to me when doing it,,, it gets a little "get it in",,,, if you know what I mean. Nipping and tucking. There is some wiggle room. The end product turned out great IMHO... I had never done anything like this before and me,,, well, I am not to hard on myself.
This is hugely subjective without instrumentation, but was it worth it? I don't know the condition of everyone's XJS, but one running properly, with the stock exhaust and proper door and glass sealing is still remarkably quiet by contemporary standards.
Are you Lexus quiet now? Any chance of a recording? (maybe you did a before and after?)
Mine was running so bad when I first started out (I didn't know how bad) that I was concerned about the amount of sound,,, but later, as I got things in a better place, it was more a heat thing. I'll have to say it was a bit of both.
I would like to say yes... But that would be dishonest...
I have NOOOO experience with these cars. The only only I've ever driven in, heard and felt the heat of is this one... I can only think that it (and 100's of other things I've done) is an improvement, lol... I have to think that OR,,, I'll go jump oft the Verrazano Bridge... Lol... This crazy car!!!
At least it's an improvement in terms of the car I walked up to 2+yrs ago now. Omgoodness...
I would also recommend, on any space that is hard to apply a sound dampener, latex paint mixed with glass microspheres. You mix the microspheres into paint and then can either spray, brush or roll.
I did this on my car as experiment and was astounded at the difference it made.
If you wanted to be real cheeky you could use an oil based paint for additional rust proofing. But latex doesnt smell and is easy to clean up so that's what I chose.
Greg in France (04-08-2020)
Mr rx-7 tt
01-20-2022 01:47 AM
