Castor measurement & shims
Hi all,
Anybody able to guide as to how to correctly measure current Front Castor angle on my car,
Next question is, regarding shims, currently there are 2 shims each side, however I query what is "standard" I have seen written that 6 shims in total with some cars having all 6 on one side to achieve 3.5 Degrees positive camber is normal.
As mentioned my car only has 4 in total, The steering feels awfully light, twitchy and will not return to centre, Camber and Toe settings are now correct.
Anybody able to help ??
Received 10,920 Likes
Lack of self-centering might be a fault elsewhere. Steering rack, ball joints, tie rods.
Doug (04-16-2022)
I think that is the data for the camber change caused by removing/adding a shim, Vee.
sunchip
04-04-2022 12:47 AM
