catalytic converters
Guest
Posts: n/a
Hello everyone.
I have an "87 XJS that is down on power. I replaced the starter yesterday due to a bad solenoid and had to remove the starboard Cat assembly. It appears plugged up and since the car has 90K miles I suppose the other side is too. If I remove them and ream them out would the reduced back-pressure effect the timing? These are the units that are attached to the manifolds, not the ones just downstream.
Thanks,
Pete Carr
Western pennsylvania
Thanks,
Pete Carr
Hi wb (Pete) welcome to the forum.
I am moving this over to the XJS section for a technical reply.
Please however, post up a non tech' introduction over in the New Member area, you know the sort of info, a bit about yourself etc.
The guys like to get to know our members, as you will discover this is a very friendly forum![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Others will chime in for the tech advice.
Received 10,872 Likes
FS[Western US]: 2001 Jaguar x308 VDP SC Catalytic Converter Housing
perezal
12-24-2015 04:16 PM
Aus V8S
11-13-2015 11:01 AM
dragonfly777
Regional
09-08-2015 01:39 PM
