CatCooler Radiators
CatCooler Radiators
Hello,
The old Concour queen needs a dose of reality and I'm going through and re-doing the cooling system. The OE rad has never been touched, the car runs "cool", but I get an occational nudge on the upper "N", so gutted she gets!
Originality aside, I've had a great luck with the Ron Davis stuff in some of my other Jags, and saw the "Super Duty Catcooler" (still not a one-pass), which looks interesting and the price is good too.
Anyone used these and / or have other suggestions?
I suppose I will go with 190 stats, but lower the aux switch temp. Don't really want to add coolant filters, but thoughts there too.
Thanks all..
Jeff
Thanks all..
Jeff
I have a CatCooler Radiator. At one time I also had my hands on the BeCool Radiator. An added bonus of the aluminum radiator is that it is ~20lbs lighter. When I had all 3 I measured the weight and size of all 3 radiators, and the BeCool and CatCooler(Wizard) were about the same weight, and all where about same thickness, but the number of fins varied. I will have to find my documentation on it.
The CatCooler is top notch quality. I believe you made a great choice. I decide on the CatCooler so I didn't have to create custom hoses to use the BeCool.
Broken_Spanners (03-29-2015)
Received 10,990 Likes
Spend money as you wish, of course, but IMHO you might be over-reacting to an ".....occational nudge on the upper "N"...." .
A CatCooler radiator sounds expensive to me.
I purchased dual electric fans, however I have not yet installed the radiator or the fans yet. The wizard/CatCooler has AN- Fitting on the radiator which you can purchase whatever style of connection you need. It comes with a fitting to work with the HE style screw connection. Due to the hoses not being cheap I had my local hydraulic shop make me some angled fitting that I can connect to AN Fittings.
Broken_Spanners (03-30-2015)
I'm effectively taking the front of the motor apart anyways, new pump, belts, t-stats and replacing the alternator, as she's barely putting out 12 volts.
No time like the present and then she's good for another chunk..
Jeff
Jeff
