causes for excessive fuel consumption?
Welcome to the forum Kp,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to XJS forum (the Advice / Feedback & Suggestion Center is only for posts about the forum). Members here with the same model will be able to help.
Do you do a lot of short trips? The warm up cycle on the v12 requires a lot of fuel. Heating up 600lbs of metals, 8 quarts of oil and many gallons of water requires lots of energy. The initial high fuel consumption can really distort the average. I got about 8 mpg on my v12 sedan while doing mostly shorty city style running around.
Received 10,873 Likes
Is that all 'city' driving, and you're not especially gentle on the throttle? If so, that's probably about right. Even with everything 100% and driven *gently* I wouldn't expect more than 12-13 mpg in all-city driving.
Steady speed highway driving should get you into the mid-to-high teens, though.
But to answer your question: a stuck enrichment switch, skewed coolant temp sensor, clogged cat convertor, broken/unplugged vacuum hose to the Marelli ECU, excessive fuel pressure, leaky pressure regulator, leaky injectors, dragging brakes......
That's off the top of my head
XKE73EIconverter
09-26-2015 10:21 AM
