Changing wheels
Old 03-15-2015 | 03:22 PM
drbill's Avatar
Default Changing wheels
I have another thread about using spacers when switching from the stock XJS wheel to and early XK8 wheel. I found this handy device to check the differences and fit. According to this, may not need a spacer at all.
Stock wheel: Diameter: 15", width: 6.5", ET: 28.5mm
XK8 wheel: Diameter: 17", width: 8", ET: 33mm
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
The following 2 users liked this post by drbill:
Jonathan-W (03-16-2015), tokyodon (03-15-2015)
Old 03-16-2015 | 01:40 PM
86jag's Avatar
The xk8 wheels will run on the front when turning at max lock without the spacer. If you get a spacer make sure you use a hubcentric spacer.
hunter34
19
09-15-2022 12:09 AM
prettydaim
03-28-2021 08:47 AM
PMKimpton
08-03-2019 09:22 PM
dsnyder586
04-04-2019 03:38 PM
afterburner1
12-16-2015 01:12 AM
Quick Reply: Changing wheels
