Check engine light intermittent when I press brake pedal
Anyone come across this before? 95 XJS 4.0 2+2 90K. Runs like a Swiss watch. Plenty of power. Seems to happen during cooler temps. Cruising along, press brake pedal for stop sign, light, etc., check engine light comes on for a few seconds then off. Intermittent. Sometimes doesn't do it. My local Jag guru has never seen or heard of it. Anybody?
It's just when I press the brake pedal whether decelerating or simply coming to a stop. Does not come on while sitting still with depressed brake. Only when slowing down and only for a couple of seconds at a time.
Also, to answer Orangeblossom below, when it first happened, I thought immediately it must be the brake warning light coming on, but as soon as it happened again, noticed it was definitely the check engine light. Not the brake light.
JaguarRookie
01-25-2018 05:41 AM
