Check Out What Marko Is Up To.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I almost cried when he broke out the cutting wheel.
(function(d, s, id) { var js, fjs = d.getElementsByTagName(s)[0]; if (d.getElementById(id)) return; js = d.createElement(s); js.id = id; js.src = "//connect.facebook.net/en_US/sdk.js#xfbml=1&version=v2.3"; fjs.parentNode.insertBefore(js, fjs);}(document, 'script', 'facebook-jssdk'));
Have you seen the Pearl's magnificent 12 throttle bodies sticking out of the massive hole in the bonnet? Well this is how they got there and how I cut the hole in the bonnet all in a couple of minutes!
Posted by Rust2Rome on Friday, August 28, 2015
Facebook Post
The following 3 users liked this post by JagZilla:
![](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-xpf1/v/t1.0-1/p24x24/10891955_10152614610048947_8528499295920242751_n.jpg?oh=8e1afab973cd9d381e52a9ffd7613594&oe=5677B2BE&__gda__=1449485656_0ee5c0c5508eeb19810f432b18a854e3)
Remove
Rust2Rome It's off the shelf Jenvey throttle bodies with custom manifolds to make them fit. Original injectors with Emerald ECU and mostly original loom. Actually some of it is 6.0 loom and some of it is 5.3! It runs so much better with them and even helped the mpg on the motorway! I say go for it!
http://www.jenvey.co.uk/products2/tw...mm-pair-tbpxxi
Remove
DCOE Throttle body 118mm long : TB body 40-50mm Pair - Jenvey Dynamics
if you are in the USA
https://www.borlainduction.com/3003-series.html
or better
http://foxinjection.com/pages/about-us
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Safari (09-03-2015)
I just went through one of the sites that Jonathan-W Referred to and came across this, a complete package for the V12, looks awesome but mind you has the high dollar amount to go with it.
Throttle Body Kits : V12 Jaguar throttle body kit SF45 - Jenvey Dynamics
Yes,
usa link and price...
have deep pockets...?
CKJR04 V12 Jaguar throttle body kit SF45 - Fox Injection
these are not the ones that Marko is using, I do believe he used 6 IDF
TFPxxi TF body 40-50mm. Pair - Fox Injection
3 pair 683.03 us$
about 2050 us $
3 pair 683.03 us$
about 2050 us $
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/fullsizerender_2__9583eaa08ad5407f1e295bfb787743256d8e99fc.jpg)
I do not see how those would fit with the aircond compres.
I think things like the AC pump would need to find a new home, not that is a bad thing to do and actually can be a worthwhile upgrade, but the big one that scares me is getting access to the plugs and dizzy(distributor). In that case you I would seriously look into things like Megajolt and have coil packs tucked under there, its not the place you would want to visit often IMO.
Tar
09-06-2015 11:24 AM
