Cherry Blossom - Restoration 1990 XJS V12
#2001
orangeblossom (01-16-2019)
#2002
As for the hub...I torched off the axle U-joint at the spindle so it's easier to handle and get into a press. We'll see if it can be seperated or the whole thing is trash.
Thanks for the encouragement...still to do: cracked rear hubs, ABS harness, weld in floor patch where the clogged AC drain tube rotted out the drivers floor pan (temporary steel plate screwed over the hole right now).
#2003
The following 2 users liked this post by Greg in France:
Fla Steve (02-18-2019),
#2004
Warmer Winter Garage For My XJS
Workshop Heater Restoration
Its not exactly a Summers day down here in the UK and in fact it would be fair to say, its absolutely Freezing and with Snow now on the way the worst is yet to come
Although just a couple of days ago, it felt just like 'Spring' so what better time could there possibly be to go for a drive in the XJS except I couldn't do that, as She wasn't Taxed!
And so the only other option which I knew I would enjoy was to go for a 'mooch' round the Scrap Yard and though they very seldom have got any Cars, they have almost everything that 'Scrap Yard Junkies' like myself can think of
This Site covers acres and they have got all sorts of things they never knew they had and so I see it as my duty to try and route it out and knew before we got there that today would not be an exception
And while I didn't really know what I was looking for, I knew that I would know it when I found it, where after we had trudged around in all the dirt and mud, the very thing I wanted sat there and just glittered like a diamond in the rough
The very thing I wanted, which was a 'Workshop Heater' and although it was beaten up and half falling to bits, once I had repaired it and if I could fire it up, then I could work on 'Cherry' or '50 Shades' my Grey XJS even in the depths of a Cold Winter
So just after I had placed a 'Fiver' in the palm of 'Scrapyard Owners' hot and sticky hand, that little Workshop Heater was now mine and so once I'd chucked it in the 'Merc' we then headed home
It does look a bit of a mess but I think I can fix it!
The only problem being that at the moment there is a piece missing, which is a short piece to chimney that should have Air Intake holes that are needed to keep the Flame burning
As you can see the old one was a bit shattered so I had to make a New one
Nothing complicated, just a 6inch piece of Tube in which I drilled some holes
Marking out the Holes on tape, so I'd know where to drill
Drilling the Holes on my Drill Press
That's it job done holes drilled!
Except of course it wasn't quite that easy, as I had to Weld it on and then take everything apart, so that I could re-plumb all the pipes, as well as one or two other mods like re-siting the Tank with the adjustable float to control the Fuel input
In order to make the Heater fit, I decided to move the Float Tank from the back of the Workshop Heater onto the side, which was a total PIA as the original fittings were 12mm and to make matters worse the Fuel Inlet Pipe had a very unusual thread!
Once I had finally managed to sort that conundrum out, then the next job on the list was to Weld on the part I'd made with the Air intake holes
Unfortunately I hadn't discovered the Art of Levitation! underneath that Lid is a 'Big Magnet' which comes in really useful for this kind of job and was originally one that was on a Magnetic Parts dish
Holding the Chimney in place for Welding using that Big Magnet
Just need to give her some Heatproof Paint and then we are ready to see if she works and hopefully keep the Garage nice and warm for working on my XJS in Winter
To be Continued............
The following 2 users liked this post by orangeblossom:
Greg in France (01-17-2019),
Mac Allan (01-17-2019)
#2005
(Continued)
(Continued)
Having rebuilt the Workshop Heater, a mate of mine who owns a Farm suggested we should Test it out in one of his steel outbuildings just in case it went bang
Which turned out to be a good idea as that's what nearly happened! as the Float controlling the flow of Fuel got stuck in the open position and as a result the Heater, had started over-fuelling
Back in the day when this Heater was made, probably over 60 years ago, the Float Tank which controlled the flow of fuel to the Heater, was in all probability considered 'State of the Art'
The only problem being that at sometime during our Test the Float got hung up in the Float Tank, which then caused the Heater to start over-fuelling
The Float kept jamming up against this fitting, which then caused the Heater to start over-fuelling
Because of the way it was designed there wasn't an awful lot I could do to fix it and so it was back to the drawing board, where I decided to do away with the Float Tank all together
In its place I fitted a needle valve, which not only solved the problem but also gave precise control of the fuel going in, as well as the output of the Heater
In place of the Float Tank, I fitted a needle valve which not only solved the over-fuelling problem but also gave precise control of the output of the heat
Outside it was Cold enough to Freeze a Bucket of Water but inside my mates Outbuilding, the Temperature quickly rose to a very Hot and Balmy 80F
Which means that I can do more work on my XJS during Winter in a nice warm Workshop for a change
#2006
Cool little heater. I've never seen one like that actually operate? I've seen similar ones in antique, and flea markets. But wasn't sure how they worked. I have a modern Torpedo heater as we call them. It sprays kerosene, or #2 diesel fuel into a chamber, and uses a spark plug style electrode to ignite the flame, and Viola Heat! It will heat my 24' x 56' shop to 60 degrees in about 30 minutes. It has a built in thermostat which shuts it off, when you reach a preset temp. My shop isn't airtight so I don't have to worry to much, of burning up the oxygen, and killing my silly self. so it's all good.
Jack
Jack
orangeblossom (01-23-2019)
#2007
Hi Jack
Its very encouraging to hear that you like the Heater and although its over 60 years old, I think the design was well ahead of its time, for while I've heard of other people trying to build these
A lot of them have a design flaw where they tend to get gummed up, as unlike this one they don't burn the fuel as fast as its fed in and if you looked in the burner of this
There isn't a single drop of Fuel to be seen, as it gassifies the moment that it hits the burning pot and then once having done so chucks out loads of heats
Where having got the inside of my mates massive metal 'Shop' to 80F then just for the sake of experiment we decided to try and push it a little bit further and very easily got it to 90F
Then turned it back down to 70F which seems to be the ideal working temperature and since his 'Shop' is over twice the size of mine, I would only need it ticking over
I've also got a Torpedo Heater but my one runs on Bottled Gas and costs a fortune to run and also you can't control the Heat and so the things I've used it for tend to be limited
But even so its always a handy thing to have
#2008
'Nurse The Screams!'
Back in the game after Flu
And Yes! it really was like one of those Scenes from a 'Carry On' Film, as when one gets knocked down with the Flue this is a real opportunity for the G.F. to show her devotion by waiting on you hand and foot as well as catering to your every whim
Well that's the theory anyway, except what actually happened was that after donning her Nurses Outfit which last saw the light of day at a Halloween Party that we went to last year, with a hemline that was so short that it could raise the dead
She entered said Patients Bedroom with all the trepidation of some crazy Scientist entering a 'Bio Hazard Area' where apart from the Nurses Outfit which was always a pleasure to see
All meals and refreshments and glasses of JD were first loaded on a Trolley and then pushed towards me with a Broomstick, which was actually quite hilarious and would have been a lot more fun if only I had felt well enough to enjoy it
Where to make things worse if they could get worse, this was extremely frustrating as we were now in the middle of one of the mildest Winters in the UK for some time and now with Spring around the corner
The only thing that I now wanted to do apart from converting my Isolation Ward back in to our bedroom! was to go and get working on my XJS and get her out of Winter Mothballs and prepped up for the first drive out of this year
Involving checking everything over to try and insure that both myself and my XJS were now back in the game and all tweaked up and ready for a 'Shake down' cruise, even if only a trip to the garage to fill up with 5 Star!
Where the desire to go out in that Car was now so overwhelming, that it was almost worse than having the Flu as well as being Tortured by the sight of the G.F. in look but do not touch mode in that very seductive Uniform
And though I've owned a lot of Cars from 'mild to fairly wild' The XJS in my view is not so much a Car but much more of what you would call an addiction, where you have to have 'Your Fix' no matter what!
Where the Price of Petrol, at over £6 per gallon and the Stratospheric Mileage of 17.5 mpg Plus the cost of Road Tax, Insurance and M.O.T. just pales into insignificance when compared to the kind of pleasure that buys
From even just one day trip in one of the finest Mainstream Sports Cars Jaguar ever produced, where it actually feels like a Privilege, just to be able to sit behind the Wheel
And well worth all the Skinned Knuckles as well as the 'Blood Sweat and Tears' together with numerous glasses of JD that you often have to go through, before you even get to turn the key!
As lets face it the XJS is certainly not considered to be one of the easiest Cars that you can work on, though as a rider to that I would say that even on a very bad day when everything is going wrong it is certainly the most fun
Then when you eventually get on the road, that is the moment at least for me that the Paranoia kicks in, as with one eye on the Temperature Gauge that can turn you into a quivering wreck if She starts overheating
You wonder if this is a journey from which you will never return, as in the event that the brakes might fail in the way they have on all of mine, then things could go 'pear shaped' very quickly!
Which is always something that plays on my mind, as the last time that this happened it very nearly spun me off the road and even though I fixed it and the brakes now feel assured it never pays to say never, that it won't happen again
Where just like my own G.F. who has a crazy 'Cookie' sense of humour, it always pays to expect the unexpected and so it will always pay to have a fairly good idea of how to fix your XJS whenever She goes wrong
Which Thanks to the Forum and a Special Mention to 'Greg in France' and 'Grant The Wizard of Oz' I know a little bit more now than when I first started
As in terms of a learning curve, as far as Cars are concerned you either need to learn real quick or else be prepared to part with a 'Shedload of Cash' or a 'Shop' could empty your Wallet, every bit as fast as you can blink
Though looking on the plus side, there's a certain satisfaction that comes from lifting up the Bonnet/Hood, at the request of a Stranger and then watching the Blood as it drains from their face when the get to see what lies beneath!
Not those neat plastic covers that you might find on a Merc which cover up an Engine that you almost never need to touch as what you have in an XJS (V12) looks more like a Chemistry Set that was put together by Doctor Frankenstein
Consisting of a mass of complicated looking silver pipes and wiring that could have been created by the Jig Saw builder from Hell, except of course for those who know, that has to be one of the reasons that we love her as much as we do
As many of those who do know including many of us, would attest to the fact that the mighty V12 is one of the Finest Engines that Jaguar ever produced and as a V12 owner I would gladly second that
And even to this very day, still find myself saying, things like Wow! and Double Wow! each time I lift the Bonnet/Hood and gaze at what's inside!
So silky smooth it feels like riding on a Magic Carpet but if you dare to unleash the Beast, then you could Scare yourself so much your legs could turn to Jelly
Its one Iconic Powerhouse in an Iconic Car and as for me I cannot wait to go down my Garage and Fill the Tank with Petrol even if that costs me at least £100 which with luck might give me enough for just a Weekends worth of 'Tripping'
As Smooth as Silk the Engine of the XJS V12 Coin Balance Test Video on my car 'Cherry Blossom'
Beauty and the Beast! Jaguars Fabulous XJS V12 Engine
Greg in France (02-18-2019)
#2009
89 Jacobra (02-23-2019),
orangeblossom (02-18-2019)
#2010
#2011
A Day At The Auction (Road Trip Video)
Due to the unusually Gorgeous Weather this time of year, we decided to take '50 Shades' my Grey XJS (aka) 'The Diva' out for a bit of a road trip, to one of my favourite places which is an Auction
To not only give her a 'shake down run' as She has been in 'mothballs' for the Winter but also to have a look around to see what was for sale, which was just about everything that you could think of
Including a 3 ton Low Profile Jack and some electric Workshop Winches and lots of other useful bits and pieces and so I've got to go back on Monday to pick it all up with the Merc and will probably need to take a Trailer with me
But since I had my 'Dash Cam' I did a bit of a Video to record the event, with a fairly nice piece of music that really needs to be played with the sound turned well up
warrjon (02-23-2019)
#2012
orangeblossom (02-24-2019)
#2013
Hi Steve
Yes you are right I know, except its such a pain to change the date that I don't usually bother, although I did put a note to explain that on the actual YouTube Video, which you wouldn't be able to see on that Post.
The Battery in the Dash Cam, is getting a bit worn out and so I have to keep it plugged in all the time or the battery tends to run down and then the Camera Memory runs out
Its almost cheaper to buy a New Dash Cam than it is to buy a New Battery, so when funds allow perhaps I'll treat myself
#2014
A Day Trip To The 'UFO' Exibition
In Rendlesham Forest Suffok
The Weather was Amazing for this time of the year, so we went for a Trip to Rendlesham Forest in Suffolk to have a look around the 'UFO' Exibition
Where there was alleged to have been a sighting of a 'UFO' in December 1980 that made Headlines round the World and although we didn't see one ourselves, we spoke to a group of people who reckon they certainly did
Though just as we got to the entrance our Dash Cam stopped recording just as we were about to drive in from the road, maybe just a coincidence but all the same it did feel very Spooky!
This is one of our favourite drives in the Summer, so next time we are out that way I'll try and get some Photos of the Exibition
As for the Dash Cam, the date is wrong because its a bit of a PIA to reset it every time as if its not plugged in the USB socket the battery goes flat
#2015
orangeblossom (03-02-2019)
#2016
Hi Daim
We've been to Norwich a few times when we've been to Wroxham on The Norfolk Broads but that A140 road is a bit of a Nightmare so not one of my favourite trips by far
Thinking of going to Hadleigh next to look round the Antique Shops, then maybe go to Frinton which is very nice and so unspoiled that when they opened a Fish and Chip Shop, it was headline news!
#2018
Hi Leo
Apart from being a great day out, its always nice to see how the other half live and Frinton has got some of the best Art Deco Shops that I have ever seen, so needless to say that I will be leaving my Credit Card at home
But not sure I will be able to resist some Fish and Chips!
Walton on the Naze sounds interesting and we are looking forward to climbing up the inside of Naze Tower which is apparently 86ft high, inside which is an Art Gallery and Restaurant
But most of all I want to Visit the Cold War Museum at Bentwaters, home of the 81st Tactical Fighter Wing, We've passed by this so many times on a day out to somewhere but so far have never been in
So that is on the Trip List, when the Museum opens again in April and then we might go to Bawdsey, where they invented Radar or so I believe, although Top of list is a boat Trip over to Orford Ness
Which used to be a Top Secret Testing Station but we have been to Orford Castle, which seems to be right in the middle of Town and is in amazing condition
Loads of new places to Visit this year, so all we need now is some Sunshine!
#2019
orangeblossom (03-09-2019)
#2020
