Cherry Blossom - Restoration 1990 XJS V12
Old 10-28-2016, 04:04 AM
Steve M's Avatar
Received 3,032 Likes on 1,702 Posts
We don't all have time to hang around tips going skip diving.
orangeblossom (10-30-2016)
  #282
Old 10-30-2016, 06:42 PM
orangeblossom's Avatar
Received 3,805 Likes on 2,634 Posts
Neither do I
Just right Time and Place.
paulyling (10-31-2016)
  #283
Old 10-30-2016, 06:51 PM
Today I put the Water Trap that I got from the Scrap Yard on my Compressor and I think the 'Thingy' on top is a Charcoal Filter?
I'm hoping the 'Thing' in the middle is a Water Trap.
The connection before the Water Trap is just for blowing dust off stuff, while the other one should hopefully Blow Dry Air.
  #284
Old 10-30-2016, 07:37 PM
Default Filling my XJS with Antifreeze
When I fitted my re-cored Radiator, I filled it up with Tap Water just to Test it out for any leaks and was getting a bit of a Weep from the Bottom Hose but as I'd done the Clip up tight, I thought that in time it might Stop.
So as I wasn't using the Car or even Starting Her up, I thought that I would leave it till I got some Antifreeze and do it then.
During which time 'Grant' aka 'The Wizard of Oz' told me where I'd gone wrong, as I was supposed to put the Clip right behind the Ridge of the Bottom Hose Outlet.
So after getting the Antifreeze, I set about draining the Water out of the Radiator by removing the Bottom Hose, which can be a PIA at the best of times, except that I'd used a 'Mikalor' Hose Clip which is done up with a Spanner or a Socket.
Which does make the Job a lot easier.
The elusive hard to reach Hose Clip on the Bottom Hose.
When I drained the Water out, I turned the Clip round so I could do it up from the Top with an Extension Socket.
By Turning the Clip on the Bottom Hose, I can now reach it from the Top with a long Extension Socket which makes it a whole lot easier.
When I finally got the Bottom Hose off, there was hardly any Water in the Radiator, so this time I took 'Grants' advice and positioned the Clip just behind the ridge on the Bottom Hose outlet.
This seemed to work as I still cant see any Weeping from the Bottom Hose.
As I've got very hard water in my Area, I was advised by some Forum Members to Mix the Antifreeze 50/50 with Distilled or De-ionised Water, so I got some and did just that.
De-ionised Water and Antifreeze already for mixing together.
All mixed up and ready to go in the Rad.
I can't believe I'm doing this as I would use Tap Water in any other Car, so this takes Decadence to another level.
I just hope the Neighbours aren't watching or they'll think I've won the Lottery (Again!)
Only a Tenner last time, so I guess that pays for the Water.
No Expense spared, I bought a New Jug and Funnel especially for the occasion!
The following 4 users liked this post by orangeblossom:
Greg in France (10-31-2016), Jonathan-W (10-31-2016), paulyling (10-31-2016), ptjs1 (10-31-2016)
  #285
Old 10-31-2016, 07:16 AM
ptjs1's Avatar
Received 3,080 Likes on 2,036 Posts
OB,
Good work. I admit that I get very precise when replacing jubilee clips, working out which is the best position for future maintenance, and then ensuring that I have optimal access with a socket. Like all of you, i have spent many hours trying to reach a jubilee clip and wondering why on earth the previous owner (or manufacturer!) decided to orientate it in that particular direction. The bottom hose on a Renault 1.2 Clio is a specific case in point......
Paul
orangeblossom (10-31-2016)
  #286
Old 10-31-2016, 08:06 AM
Received 1,209 Likes on 918 Posts
Wow...I am so not used to seeing Blue coolant! I'm only used to messing with Predator's blood!
  #287
Old 10-31-2016, 08:10 AM
Hi Paul
I found that out the hard way!
https://www.jaguarforums.com/forum/x...e-24-a-115152/
  #288
Old 10-31-2016, 08:14 AM
Hi Bro
I think that 'Leaves' a lot to be desired
  #289
Old 10-31-2016, 08:47 AM
Originally Posted by orangeblossom
Hi Paul
That was gold OB....the forum's # 1 comedic journalist goes to you!
  #290
Old 10-31-2016, 10:43 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
OB, is that coolant the RIGHT spec? Not being stupid, but loads of different coolants out there and the result was shown when 2 are noncompatible... Costs a lot of time, work and effort to get the problems then sorted...
  #291
Old 10-31-2016, 12:07 PM
Hi Daim
Yes its definitely the right stuff.
Daim (10-31-2016)
  #292
Old 10-31-2016, 12:09 PM
Daim's Avatar
Good... I like to make sure people understand how important this is...
I'll still be using my "universal" stuff from Prestone though... No reaction possible
The following 2 users liked this post by Daim:
orangeblossom (10-31-2016), paulyling (11-01-2016)
  #293
Old 10-31-2016, 06:33 PM
With New Brake Pipes on Order (Two Fronts and a Rear) It was now time to remove the Old Flexible Brake Pipes.
As expected they were Rusted absolutely Solid.
Rusted Solid on both sides and the only way to get them off was with a Cutting Disc on an Angle Grinder!
Time for 'The Nuclear Option' sometimes it really is the only way.
I told you they were Rusty!
No amount of Penetrating Oil was gonna shift that!
Nearly There! Lots of patience and a steady hand but don't cut through the Sensor Wires which are just above it.
Finally out and all ready for the New Flexible Brake Pipes (When they arrive!)
All you need is a drop of 'Sea Air' and this happens!
My Sharpest Tool in the Box
A pair of Am-Tech 9in Locking Pliers
However did I manage all these years without them.
Ebay: Around £5
The following 3 users liked this post by orangeblossom:
Greg in France (11-01-2016), Jonathan-W (11-01-2016), paulyling (11-01-2016)
  #294
Old 11-01-2016, 02:52 AM
Greg in France's Avatar
Received 9,300 Likes on 5,462 Posts
Managing that without making a huge hole in the wing is brilliant OB. Sometimes using the watchmaker's toolkit is the only way!
Greg
The following 2 users liked this post by Greg in France:
orangeblossom (11-01-2016), paulyling (11-01-2016)
  #295
Old 11-01-2016, 06:00 AM
Greg
Hi Greg
You are right, I also made a Video but on playback it was much too painful to watch!
  #296
Old 11-05-2016, 12:00 PM
The next Stage didn't exactly go according to plan!
First they sent the wrong Brake Pipes and then they sent the wrong nuts!
Just a tad on the large side for an XJS!
Pic was on an Old Brake Pipe while waiting for the New ones to arrive.
So while I was getting all that sorted out, I finished off doing the Calipers.
by using a 'Torque Wrench' to tighten the 'Caliper Bolts' doing this in increments up to 50ft lbs.
Using a 'Torque Wrench' to tighten the Caliper Bolts.
Caliper Bolts Tightened up to 50ft lbs
Having Tightened the Caliper Bolts to 50ft lbs the next job was to put the Locking Wire on.
Stainless Steel Locking Wire to Lock the Caliper Bolts.
Putting on the Locking Wire.
You do get Prizes for Neatness
obviously a talent going to waste.
The following 2 users liked this post by orangeblossom:
Greg in France (11-06-2016), paulyling (11-05-2016)
  #297
Old 11-05-2016, 01:20 PM
Nice one OB. I didn't realise there was nuts with the holes drilled out for locking wire. Is that just for the brake calipers? You'd be "nuts" not to install them though
We use that wire all over the rig up at heights in our derrick and top drive as a nut like that falling from heights is very dangerous
We have a special tool for that wire. Basically like a pair of plyers but has a locking mechanisim and a spindle. You pull back and "wella" it twists all your wire. (probably over kill if you don't have to do too many though).
orangeblossom (11-06-2016)
  #298
Old 11-05-2016, 02:21 PM
ptjs1's Avatar
OB,
Everyone should have a set of locking wire pliers! It's very therapeutic using them! And with a 7" set available for less than a tenner, it's a no-brainer. Much neater than manually twisting wires.
Paul
The following 3 users liked this post by ptjs1:
Greg in France (11-06-2016), orangeblossom (11-05-2016), paulyling (11-05-2016)
  #299
Old 11-05-2016, 02:30 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
wire twisting pliers, invented at Boeing aircraft Com. Seattle Wa, USA.
its in there museum there!
The following 2 users liked this post by ronbros:
  #300
Old 11-05-2016, 05:49 PM
Hi Paul (PTJS)
Nice idea but maybe not worth getting with just a couple of wires to do, as I cannot see I would need them for anything else.
Unfortunately 'Rain Stopped Play' or I might have got the Brake Pipes on as well.
paulyling (11-06-2016)
Quick Reply: Cherry Blossom - Restoration 1990 XJS V12
