Cherry Blossom - Restoration 1990 XJS V12
Old 02-24-2017, 05:12 PM
orangeblossom's Avatar
Received 3,771 Likes on 2,611 Posts
Sorry Daim
Don't get it (could you explain a bit clearer)
Why would you want to 'Crimp' Press on Ferrules?
Surely its one or the other?
  #842
Old 02-24-2017, 05:37 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Originally Posted by orangeblossom
Sorry Daim
If you use a size larger you'll want to crimp them on to makemsure it is all tight... Press on are fine wirh matching hose and pipe. Crimp them on top and you can make the fit even tighter...
orangeblossom (02-24-2017)
  #843
Old 02-24-2017, 06:48 PM
Hi Daim
Got it now but 'I would have thought that' a 'Crimp Ferrule' and a 'Push on Ferrule' were made of different materials and could only be used for one thing or the other.
But having no experience of either, I don't know.
  #844
Old 02-25-2017, 03:49 AM
Daim's Avatar
The ones in my pictures a couple of pages back are push on and crimpable... So you can either use them for low pressure setups or high pressure setups. The ~3.5 Bar the pump makes is not high pressure, so you can use them to make the next size hose fit and then crimp them...
Although I think the 8 or 9 mm hose fits the normal hard piping as well as the rail piping... Should be a little bit of expansion in the rubber hoses...
orangeblossom (02-25-2017)
  #845
Old 02-25-2017, 05:20 AM
Hi Daim
OK Cheers!
  #846
Old 02-25-2017, 04:39 PM
Default Hydraulic Oil Pipe Question
Hi Guys
Is it possible to buy Flexible Hydraulic Hose about 2ft in length OA that can be bent into this shape without 'Kinking'
The Loop part need not be quite so tight as long as the ends can be kept straight and are not more than 2ins apart and the inside diameter of the hose is not less than 25mm.
Is it possible to buy 'Non Kink' Hydraulic Hose to recreate this fitting without incorporating the Metal Pipe.
There would just be the fitting Crimped on each end.
  #847
Old 02-26-2017, 01:39 AM
Greg in France's Avatar
Received 9,247 Likes on 5,431 Posts
I doubt it, but any hose shop can re-use that steel U piece and the threaded ends to make a new one.
Greg
orangeblossom (02-26-2017)
  #848
Old 02-26-2017, 02:34 AM
Daim's Avatar
Looks like an oil cooler bypass pipe!?
  #849
Old 02-26-2017, 03:05 AM
Hi Greg
That Metal Bend is just a 'mock up' of Two Pieces of steel pipe, tack Welded together as a pattern in the hope of getting it replicated by a Hydraulic Shop.
But since my local one closed down (some years ago) the nearest one to me, does not do any pre-forming with Steel Pipe.
Although my nearest one an hour away, is willing to crimp the ends on to some hydraulic pipe but won't guarantee it won't kink.
  #850
Old 02-26-2017, 03:09 AM
Hi Daim
That's what it is and just a temporary measure until I have given the Car a few shakedown runs.
The Pipe in the Photo is just a 'mock up' to use as a pattern but my nearest hydraulic place doesn't bend Steel Pipe.
  #851
Old 02-26-2017, 03:11 AM
Daim's Avatar
Why not use some hose instead? Long enough and it won't cause any blocks...
  #852
Old 02-26-2017, 10:40 AM
Hi Daim
That was sort of my Original Question about finding Hydraulic Hose that won't kink, so I could curve it round in a similar shape.
  #853
Old 02-26-2017, 10:52 AM
Daim's Avatar
Hi Daim
Your local hydraulic Shop should have a mat hing hose which won't kink. Even if it means to be longer...
  #854
Old 02-26-2017, 12:44 PM
Hi Daim
I've heard of a Trick Question but never a Trick Answer!
At which point I was wondering what a Mat Hing hose was!
Obvious to me now that it was a Typo (Lol)
Not much space for a long hose but I'll see what sort of bend we can get without kinking.
  #855
Old 02-26-2017, 01:26 PM
Daim's Avatar
Yeah, was supposed to be matChing hose
You don't need meters/yards of it, I think say a couple of feet would do... Say around 50-60 cm. There is enough space there, if it is only for a "bodge" to make sure the engine doesn't have any issues, then I'd not worry about the length.
  #856
Old 02-26-2017, 05:29 PM
Hi Daim
Cheers!
There is not a massive amount of Space in the place where its got to go.
But do you know what would happen, if the Oil was unable to travel through the by-pass Pipe, as once the under tray is in place, it will be out of sight for a while.
  #857
Old 02-26-2017, 05:44 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
OB the other option is to use braided hose and screw on JIC fittings, I did this with my new transmission cooler hoses. You can also get braided to hard pipe adapters not sure if they come that big but even if they didn't SS braided hose is mighty tough.
Greg in France (02-27-2017)
  #858
Old 02-27-2017, 02:40 AM
The engine would seize and the bearings throughout would be ruined. OB, I side with the WoOz here: buy the correct oil cooler and pipes, if you are going to keep the car. Or, and this is quite Ok too, go to these people:
Mocal Oil Coolers : Oil cooling products for automotive, aviation, marine and industrial applications
and buy an oil cooler kit, complete with cooler and fit that in place of the OEM one. This will save you about 300 quid! If you are going to keep the car, why bother spending time and money on a bodge when you will have to buy the real thing anyway? I think the shakedown idea is a bit of a red herring!
Greg
  #859
Old 02-27-2017, 02:55 AM
Hi Warrjon
That is not only a great idea!
But also the perfect solution to the problem.
All I need are Two Cone Fittings about £8 each UK
And then a piece of Braided Hose with Screw Fittings on each end to go on the other end of the
Cone Fittings.
I can get all this Stuff on ebay and then I can fit it myself.
But do you happen to know the Thread Size of the Fitting I would need?
Items in HARRIER FLUID POWER LTD T/A FLOWFIT store on eBay !
Does anyone know the Tread Size and Fitting Size of this Cone Fitting that goes into the Oil Cooler Pipes under the Radiator where the Rubber Pipes from the Oil Cooler used to fit.
  #860
Old 02-27-2017, 03:08 AM
Hi Greg
Great idea!
I can get one from Demon Tweeks on ebay, should have change from about £150 including fittings.
any recommendations on which one to get?
Quick Reply: Cherry Blossom - Restoration 1990 XJS V12
