Cherry Blossom - Restoration 1990 XJS V12
#981
Jonathan-W (04-25-2017)
#982
Hi Warrjon
There are 3 Copper Washers in that Stack.
One on either side of the Spacer and one at the Top of the Banjo Bolt, which is an 'Original One' that I thought it better not to disturb, as it was such a tight fit.
It you look very carefully you can just about see it under the Banjo Bolt head.
#983
#985
all three ends had weep holes where the rubber covered but the clamp was not that far up....
I believe the failure happen because the very top run across the radiator had developed three pin hole leaks this kept the coolant level too low so there was vapor not coolant and that let it corrode...
I will look for a new pipe, if you have a link I will thank you for it...
the after picture says it all... two years no leaks!
I check... weekly as I left one or two old hoses on
just looked through
https://www.jaguarclassicparts.com/u...ooling-system/
I failed to find that pipe... help requested!
orangeblossom (04-25-2017)
#986
Here is the JCP link:
https://www.jaguarclassicparts.com/u...-5-3-6-0-litre
It is NLA but they do turn up on ebay in the UK very occasionally. My own view is that your repair is excellent, and very likely stronger than the original!
Greg
Greg
The following 2 users liked this post by Greg in France:
Jonathan-W (04-26-2017),
#987
Hi Jonathan
I think your repair is excellent and in no way could be considered to be a 'Bodge'
If New Parts are unavailable or very hard to come by, then you have to do what you must do and try and overcome the problem the best way you can.
It not as if its out of sight and therefore very easy to keep an eye on and being a bit Paranoid, I always do a 'Pre-Flight Check' before I do a trip.
My Bleed Pipe is in very good condition but even so I had a Hose Clip fail and that was a Stainless Steel one.
Anything can happen on an XJS just the same as any other Car.
#988
My Red Car is a dead Car and died with a dropped Valve and as for me I'm too upset to Cry, after all the work I've done on her.
Yesterday She Started on the Button and ran like a New Car, which She almost was at only 24,950 Miles from New.
But today was a different Story as when I went to turn her over, all Hell seemed to break loose and it sounded like a Hammer that was banging on an Anvil.
Although I never managed to get the Engine to run, as She was turning over I could hear that Metallic Clattering Sound that everybody dreads.
And so its looking like the end for Her.![Icon Nic](https://www.jaguarforums.com/forum/images/smilies/icon_nic.gif)
R.I.P. 'Cherry Blossom' April 25th 2017.
#989
orangeblossom (04-26-2017)
#990
The following 2 users liked this post by alabbasi:
#991
If I were there I'd buy you a drink. Four times.
Then I'd tell you I may know where an engine is and ask what you've planned this weekend.
I hope you choose to double down on Cherry Blossom. Too nice to let go! Bedsides, what else are you going to spend your time on that looks so good and gives you the same happiness?
The following 3 users liked this post by JigJag:
#992
Don't give up, look at it as an opportunity to pull the heads and do some work. Aluminium can be welded so any damage to the head can be repaired.
Or buy a 6.0L
Grublogger recycled Jaguar parts - engines and engine components
These guys have one for 800quid (I don't have GBP sign on my keyboard).
Or buy a 6.0L
#993
#994
Received 10,871 Likes
#996
The following 2 users liked this post by Some Day, Some Day:
#997
#998
#999
#1000
Are you actually really sure it is a valve seat that has dropped? I mean, these engines can make many, many different noises.
See if you can borrow an endoscope or buy a cheapie on eBay/Amazon to plug into a laptop. You will be able to see a lot more.
Think positivly! If a seat has dropped, then the next challenge has been accepted: Remove heads, have them sorted out.
Iirc Barratt had an offer on some HE heads a few weeks ago. Something like £300 per head (NOS). Of course new valves and springs were required).
The following 2 users liked this post by Daim:
Greg in France (04-26-2017),
