Cherry Blossom - Restoration 1990 XJS V12
Old 08-24-2017, 06:03 AM
orangeblossom's Avatar
Received 3,771 Likes on 2,611 Posts
Default What Grease should I use on the Hub of 'The Ice Princess'
Grease Is The Word
What Grease should I use when putting back the Hub on 'The Ice Princess'
Should I use the Clear/Yellow
High Temperature Grease
General Purpose Grease
Or Molybdenum Grey Grease
What Grease should I use on these Hubs?
  #1382
Old 08-24-2017, 09:39 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
A good wheel bearing grease. Something with a high temperature stability.
orangeblossom (08-24-2017)
  #1383
Old 08-24-2017, 09:45 AM
Ok Daim
Cheers!
  #1384
Old 08-24-2017, 12:17 PM
Daim's Avatar
As you can see OB, I'm in the middle of taking my ABS unit apart. Just to make sure it works properly before I reinstall it.
Here's the pedal. At the top are some brass bushes. Mine have been replaced before (some crude hammer dings in the material). If it was never greased, as it is supposed to be, it will wear. Especially since you always use the brake pedal...
  #1385
Old 08-24-2017, 01:58 PM
Hi Daim
I will be following this with interest!
But what do you know about the Mercedes 190e (1992) with 1.8 Engine. (everything I hope!)
The Fuel Pump keeps cutting out and then the engine has to be restarted.
Its now got so bad I can't drive it (so much easier fixing a V12)
BTW have you found any way of Adjusting the Pedal?
  #1386
Old 08-24-2017, 02:10 PM
Daim's Avatar
IIRC it has the KE Jetronic?
If the pump cuts out, I'd check the fuel pump relay. Common problem with those KE's. The fuel pump is less likely a problem. But the relays suffer. Amd as they get hot, they can have some issues. See if you can find the relay and replace it. Shouldn't be a fancy rare part.
Should be located around the battery. It is a longish black box wirh several pins.
Something like this:
These seem to have a corrosion problem and after a certain amount of it, it'll cut out. New start is enough to kind of reset it. Otherwise theree isn't much that can go wrong...
  #1387
Old 08-24-2017, 04:10 PM
Hi Daim
That was my first thought as well, there are lots of these on ebay
that are supposed to fit a Merc 190e but when you check the Compatibility chart they don't,
even though they have the same Pin Layout!
My daily driver is a 1992 Merc 190e (1.8)
The number on my fuel pump relay is 003 545 20 05
I can only find a S/H one about £60!
most of the others with the same Pin Layout are £16-£20 eg 003 545 24 05 but I'm told it won't fit.
Any ideas?
  #1388
Old 08-25-2017, 02:27 AM
Daim's Avatar
Tue picture was meant as a shape example.
Used ones go here for like €30. New like €60-100...
I personally wouldn't buy used relays if available new...
orangeblossom (08-25-2017)
  #1389
Old 08-25-2017, 06:23 PM
Default Not Going Out! I'm still Suffering from 'Hay Fever'
One of the Best Days of the Year but I can't go out as I'm Suffering from
HAY FEVER!
Brought on by an irrational Fear of being crushed by a Trailer of Hay and cheating almost certain death Twice in the Same Day!
This should never have happened as there I was living the dream, driving along in my Red XJS.
With the GF at my side, looking as radiant as can be with her colour coded hair that she must have got out of a bottle.
And cut with a Flymo that must have got out of control.
'You've got to blame the parents'
Anyway there we were 'Wafting Along' with the Sun bursting out of an Azure Blue Sky, with hardly a care in the World.
On our way to Aldeborough and their famous 'Fish and Chip Shop' which is always on the 'Telly'
Which took us through the Forest on one of my favorite drives, where you hardly see a Car except for some nice Classics.
Ferrari's, 'e' Types, Astons, at one time or another, I've seen them drive through there.
Its a lovely little stretch of road that really got it all, from swooping hilly sections to really tight blind bends.
Which makes the drive to Aldeborough very well worth while, as you finally get to the Crossroads and then turn right into the Town.
Where inevitably someone has a nicer Car than you, but not Today!
The only problem being, that were were not there yet and had it not been for 'The Jaguar Gods' We would never have made it at all.
As a Farm Trailer loaded with Hay had just lost all its Bales, that were now scattered all over the road, right in front of us!
Where a few yards either way could have had a very different ending.
Although being hit by a Bale of Hay, could never have mussed up her hair, any more than it was.
So having dodged a bullet, we wafted on our way and were looking forward to those 'Fish and Chips'
What on earth could possibly go wrong!
Well just a few hundred Yards down the road, yet another Farm Trailer had lost all its load!
But we eventually made it unscathed and had 'Fish and Chips' on the Beach.
After which we then had an incident free trip all the way home reflecting on our good fortune.
Just part of life's rich pattern, these things happen.
And though I've never been an Angel, I nearly was that day!
Where for some strange reason, I've gone right off 'Fish and Chips'!
  #1390
Old 08-26-2017, 08:46 AM
Now That's What I Call
Proper
Saturday Morning Shopping!
Antifreeze-Deionized Water-Dot 4 Brake Fluid -ATF-10/40 Semi Synthetic-Oil Filter and a couple of Tins of Contact Cleaner.
  #1391
Old 08-26-2017, 09:52 AM
Hi Guys
I just bought 25L of Blue Antifreeze, or at least I thought that was what I was buying, as it even said BLUE on the Invoice.
But When I got home and Checked the Label, I found they had given me PURPLE by mistake.
What is PURPLE ANTIFREEZE? I've never ever heard of it before.
  #1392
Old 08-26-2017, 10:15 AM
Daim's Avatar
The COLOUR has nothing to do with the PROPERTIES of the fluid. It is like saying should you use white tooth paste or white with red stripes?
Many manufacturers change the colours as they wish to. Red, yellow, green, neon yellow, purple even brown is about... You can mix and match BUT you need to know what base it is (silicone, glycole, ...) in order to prevent it flaking and crystalizing...
Read what the "ingredients" are on your tub and compare them with those on your previous tubs. That is the best way to make sure if it is compatible or if it isn't.
And because of exactly THESE reasons, I always use universal coolant. No silicon content. No way of it flaking out. Heck, you can add it to ANY coolant in the engine already and nothing happens... My XJ-S will be getting the same stuff as my XJ8 gets...
  #1393
Old 08-30-2017, 07:14 AM
Default Checking the Auto Transmission Fluid (ATF)
Checking The Automatic
Transmission Fluid
Having never checked the Level of the Automatic Transmission Fluid because for one thing I didn't know how to do it.
I thought that I'd better start now, so first off a big Thanks to Paul P.T.J.S. and daverb for showing me what to do.
(1) Step One: Warm up the Engine.
Warming up the Engine and She Started on the Button as well!
Must be all that TLC and Money I'm throwing at her.
(2) Step Two: Find the Transmission Fluid Dipstick
The Transmission Fluid Dipstick.
I was wondering what that was for.
Transmission Fluid Dipstick being pulled out to Check the Level of the ATF
The First time I did this was when the Engine was Cold and Not Running.
(1) Remove Dipstick
(2) Wipe Dipstick Clean
(3) Re-insert Dipstick
(4) Remove Dipstick to Check the Level
This Photo was taken looking down from above
The ATF was there right to the Top of the Groove
The Dipstick Marks looked a bit Confusing but the ATF was right to the Top of the Groove (Guys, is that OK?)
(3) Step Three: This time checking with the Engine Running
(1) Cycle through the Gearbox (with the foot brake on!)
(2) Clean Dipstick
Photo Taken from above Same as before
When I checked the Level this time, I did so while the Engine was Still Running
Having Checked the Level of the ATF but this time while the Engine was Still Running, the ATF Level was about half an inch from the Bottom of the Dipstick.
The Fluid was a very nice light Red Colour and didn't smell burnt, so I'm hoping that all is ok.
And now I know how to do this, I will be Checking it at least once a Week.
  #1394
Old 08-30-2017, 07:45 AM
Daim's Avatar
Technically it should be enough to check the fluid level when cold. So ice cold engine and then pull the dipstick. The Rodney (ha, get it? Rodney <-> Dip stick <-> Dellboy...) should have a cold mark on one side and a warm mark on the other. Normally the level is higher when warm and lower when cold (at least that was my experience with other brands and autoboxes like ZF, Aisin Warner, Jatco, ...). Most important though is to have the car TOTALLY even standing. No incline /decline. It MUST be flat and level. Otherwise the reading can be bad...
orangeblossom (08-30-2017)
  #1395
Old 08-30-2017, 07:57 AM
Hi Daim
Cheers!
But on my Car the Level was Higher when Cold than it was when it was Hot.
  #1396
Old 08-30-2017, 08:08 AM
Doug's Avatar
Received 10,872 Likes on 7,151 Posts
Originally Posted by orangeblossom
Hi Daim
Cheers!
Was the engine running when you checked it?
  #1397
Old 08-30-2017, 08:09 AM
Doug's Avatar
Never mind. I see that the engine was running, sorry !
  #1398
Old 08-30-2017, 08:16 AM
No Probs Doug,
A Double Check is always well worth while.
  #1399
Old 08-30-2017, 08:32 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
OB,
One of the difficulties with checking in any way other than "hot and cycled" is that fluid level in boxes can be very misleading at any other time. For example the ZF box in the 4 litre tends to "drain back" when left. So the level can rise over a number of days. (As an example, see how much fluid will continue to drip quite significantly out of the box after you've removed the sump and filter!) Which means that if you check it when cold, you really need to do it when it's cold and been standing for exactly the same amount of time, every time you do it That's really difficult to achieve. IMO It's a much better indication to always check it with car level and box "hot and cycled".
It's good that your fluid still seems reddish but it's definitely still due a filter and fluid change!
Paul
The following 2 users liked this post by ptjs1:
Daim (08-30-2017), orangeblossom (08-30-2017)
  #1400
Old 08-30-2017, 11:35 AM
Hi Paul
Cheers!
Points noted!
But since I won't be using 'Cherry' much for the rest of this Year and the Car had FMDSH when I bought her.
I've had to drop this down the list of priorities. (as the Fluid does look good enough for the moment)
In favor of:
(1) Seeing if I am able to Start 'The Ice Princess'
(2) Fitting New Calipers to 'The Ice Princess'
(2) Fitting New Master Cylinder/Actuator to 'The Ice Princess'
(3) Bleeding the Brakes of 'The Ice Princess'
(4) Drain and Re-fill Anti Freeze on 'The Ice Princess'
(5) Putting New Steering Arm on 'The Ice Princess'
(6) Getting 'The Ice Princess' out of the Garage and replacing Her with 'Cherry Blossom' which I have totally bonded with and is the love of my life (at least Car wise)
paulyling (08-30-2017)
Quick Reply: Cherry Blossom - Restoration 1990 XJS V12
