Alex
Is there some sort of collecting sump or suchlike thing in the tank? If it is flat bottomed there must be, or the engine could miss on a fast corner with even half a tankful. Is it possible that whatever is there is not functioning as it should?
There is a Steel Ring surrounding the Pump (a bit like a half height Saucepan) with a hole in the Side to let Fuel in, so when you go round Corners you don't get Fuel Starvation, as the Tank is Very Long and Very Wide
That 2 inches of Fuel is not reserve, as its below the Fuel Sock Filter where the Pump would be unable to suck it up
And so to all intents and purposes that 2 inches of Fuel is totally wasted and just adds to the depth of Fuel that is needed to Cover the Fuel Sock so that the Fuel Pump can suck it up and deliver it to the engine
I meant it on the lines of fuel sender... If ou need 4-5 gallons of fuel as a minimum in the tank before the tank gauge notices it, well, that is one hell of a reserve
Removing and Repairing The Speedometer on 'Carmen'
1995 XJS 4.0L with AJ16 Engine
Everything was AOK until I Changed the Battery, at which point the Speedometer Needle suddenly flicked right over to 150mph and having done so stayed there and then would not go back
It must have been an Electrical Spike or something like that and though I'm told this doesn't happen often, I have also been told it's 'The Nature Of The Beast'
And the only way to fix it is to take the Instrument Binnacle out of the Dashboard and then sort of revolve it till the Needle on the 'Speedo' drops right back where it should be
But while the thought of removing the Binnacle can freak some people out, trust me when I tell you its a very easy job, that a 'Shop' might want to charge you a couple of hundred bucks for them to do
I did this job at Sundown when I could hardly see what I was doing, hence the 'not so good Photos' that accompany this 'Saga' so the first thing that you need to do, is remove the inner plastic trim that surrounds the Binnacle on the inside
3 Phillips Screws are holding this in but best to do the top one first before the one either side
See Photo:
You should recognize this piece of Trim that sits inside the Binnacle and there are 2 of these joined in the middle
Take a look at the Furry bit that goes at the bottom, as once having removed the Screws you have to carefully 'Jiggle' it out, using the round end of a blunt kitchen knife, or you might break the Plastic surround as that would be really bad news
Once that Plastic Trim is removed, get a very sharp knife and Carefully prize out the plastic Indicator Covers, these come out very easily as they are just snapped into position
There is one on each side of the 'Speedo Binnacle' and underneath those little plastic Covers are 2 Phillips Screws (one each side)
Once those 2 Phillips Screws are removed, you are almost there!
Just above the Battery Charge Indicator you can see a hole where I have prized out one of those plastic covers near the Indicator, behind which are 2 Phillips Screws (one screw either side) they only need a little 'Flick' they practically fall out
Now for the Fun Part: Taking the Binnacle out
Very easypeasy but you do need to be Careful and use a very 'Light Touch'
First off lower the Steering Wheel, or else pull it forward as far as it will go, then take hold of the Top of the Binnacle and gently pull it forward, so the 'Speedo' faces down
Then as you look into the Cavity, you will see a couple of Multi Plugs, that plug into the back of the Binnacle and these need to be disconnected
Very Small hands would be a massive advantage but even so its not that difficult, though just make sure that you do not damage the Printed Circuit on the back (or trust me that would really spoil your day!)
Then once those Plugs were disconnected, I could very gently slide the Binnacle out from between the Dash and my 'Uber Swanky' Wood and Leather Steering Wheel
Gently does it! Sliding the Instrument Binnacle out between the Dash and the Steering Wheel
Having done that, all I then did was to turn the Binnacle end over end until the Speedo Needle fell back in position
Nearly there, as the Speedo Needle falls back into position
Job done! Speedo Needle is now back in position where it should be
Leaving a great big hole in the Dash for when I put it back in
Don't damage the Printed Circuit, or it will spoil your day!
I'm not planning to put it back just yet, I want to put on a New Battery first just in case it happens again
All wrapped up and ready for when I put it back
This is a 'Walk in the Park' job if ever there was, also the same on the Pre-Facelift
Testing The Valves In The Teves Mk111 ABS Valve Block
Prior To Fitting In 'Cherry Blossom' 1990 XJS V12
While going through some Videos I made some time ago, I came across this one for Testing The Valves in the ABS Valve Block of the Teves Mk111 Master Cylinder Actuator which somehow got left out of my 'Cherry Blossom' Restoration Thread
And so I thought I would include now, so I would know where to find it should I ever need it in the future
As a Broken Ribbon Connector in the Valve Block, can cause all sorts of problems, including having your XJS take a sudden and Violent dive to the side of the road
Which is a very easy and inexpensive Fix, which involves re-wiring the Valves with high temperature silicone wire which in the interests of Safety should only be attempted by a Professional Soldering Shop
After over 20 Years of Heat and Vibration, the Ribbon Connectors in the ABS Valve Block can go 'Crispy' and break off, where even the weight of one of those Valves if it fell out of the Valve Block could be more than enough to break a Ribbon Connector
Can't believe its that time of the Year once again, where Summer had finally faded away and Christmas has come out of nowhere but it is what it is, so now is the time to get my Cars ready for Winter and look forward to the Spring
Where with 'Carmen' my 1995 XJS 4.0L nearly done and dusted and ready to go and get her MOT, the only thing left to fix on her is the CD Player, that got put on the back burner because of the Fire but more about that later
As my pride and Joy 'The Ice Princess' will be spending the Winter out doors, as at the moment She is on the Lifter, waiting for me to psyche myself up to drop the rear cage, so that I can then remove a broken brake bleed nipple on the rear Caliper
Which is a job that I will now be leaving till the Spring, as She cannot be moved at the moment because of that and the fact that She needs a new Brake Pump and so I wanted to make sure that She would be able to survive throughout those Winter months
Where job Number One was to run a check on her Antifreeze and then if possible Start her up, as She hasn't run for quite sometime, to keep her fresh and avoid any possibility of having blocked Injectors
And so in order to do all that stuff, I decided to lift the Bonnet/Hood up as high as it would go, which meant undoing the Bonnet/Hood Struts and tying it up in the air
Since I keep the Strut Nuts greased, removing them was easy
I but the bolster there in case the Bonnet/Hood fell while I was tying it up
Lots more room to work now, just make sure that you don't crush the grill
The Antifreeze was good for -20c but in the UK the Coldest Weather we get is around -5c
'The Ice Princess' looks a bit of a 'Bobby Dazzler' especially with those nearly new Wheels that I got from a Scrap Yard for £150!
Inside 'The Ice Princess'
All the Lights are flickering but I'm wondering if She will Start?
I've never heard of that Stuff before, I'll have a look at the reviews
OB
RON 95 fuel can quite quickly turn to jelly if left in a fuel tank for a few months. 98 RON which all V12s should use IMO, is better in this regard; but even so, in a car not being used for several months, a fuel preserver is a great idea. To be effective it is important that the treated fuel is run though the system for a few minutes, so the injectors, fuel pressure regulators, pump internals, etc etc are all bathed in treated fuel while not being used.
I put it in all my rarely used motor-powered kit (generator, rotavator, etc) and they always start no bother, even after more than a year's inactivity.
The one thing I need to do on this Car is to drop the rear Cage because I have got to remove a broken Bleed Nipple and its also a job that I've been putting off for what I happened to feel is a very good reason
As from what I've been reading on here, one of the biggest problems seems to revolve around removing the Speedo Sensor which is in the rear axle, which looks seductively easy to take out except that its not
And so before I start on this Job, I need to find how to unplug it from inside the Boot/Trunk, as although I'm pretty sure the plug is in there somewhere, I think that I am going to need a 'Mirror on a stick to try and find it' as it seems to be hidden away
But since the Weather is not ideal for crawling under the Car, this is a job that I am also putting on the 'back burner' until Spring, as I've also got to get 'Carmen' ready for her MOT my 1995 4.0L XJS Convertible
Where now with these two excuses in hand, I am feeling better already but I want to get all of my 'Ducks in a row' before I even take a Spanner to her, or I have a very good feeling that I could get in one hell of a mess
Although the one thing that I did do was to remove one of the Mufflers, so that I could have a try at getting that broken bleed nipple out, which has been spectacularly unsuccessful at this present time
And so with Winter drawing near, I went and checked her Antifreeze and then I thought I'd try and Start her up, as She hasn't run for quite sometime
Where having connected the Battery, I turned on the Ignition and all the lights lit up, where to my surprise She started on the button! and although just a little bit noisy with that rear muffler missing
She was ticking over very nice and smooth and also had instant Oil Pressure which went right up to 60psi, where after running her right up to operating temperature, I then switched her off and Covered her up for the Winter
Having first made a short Video, of her Engine running
As your "Winter Princess" is the same as my 1989, if I remember correctly it was an 89, it is located in the rear left. Remove the carpet around the filler corner. You'll find a plug there with a cable which leads through the boot, behind the spare wheel and disappear into a rubber grommet. IIRC it has a grey coloured wire cover. That is the sensor. It will unplug easily and can be pushed through the grommet opening. No real fuss there, mate
As removing the Speedo Sensor, is the thing that's been putting me off dropping the IRS Cage, as its almost impossible to get to with a Spanner and so as soon as the Weather clears up, i'll try and find that plug
That was very interesting and I never new that, so if/when I find that plug I'll try and get some photos to help myself and other who may have to do that job, so thanks again
So Decided To Make Some Stuff To Detail My 1990 XJS V12 'Cherry Blossom'
One of the most useful Tools that I have ever bought was this little Mini Sander which can get into places other Sanders cannot go
And so I decided to 'Mod' it and turn it into something to Polish those hard to reach places in the Engine Compartment, with a 'Scotch Bright' type Pad
Where although you can buy these Polishing Pads for Mini Sanders like mine, they can be quite expensive so I thought that I would try and make my own
So first I got a 'Scotch Bright' type Pad and a pair of Scissors
Making a Polishing Pad for my 'Mini Sander' with a 'Scotch Bright' type pad
A 'Scotch Bright' type pad and 'worn out sanding disc' with the all important 'Hook and Loop'
And my trusty Glue Gun! 'What's that for?'
Next I glued the old Sanding Disc onto the 'Scotch Bright' type pad and cut it out
With the 'Hook and Loop' uppermost, I could put it straight onto the Sander
This worked so well that I also made one with the Pad the other way up for some of those more aggressive cleaning jobs
Too dark in my Garage to get some decent photo's but the results were so outstanding, that I made dozens of these
Not recommended for Bodywork: except maybe under the Spoiler, as my reason for making this was to Clean and Polish the Engine Compartment
