'Cherry Blossom Update' I'm going to try and Start her up Today!
orangeblossom (04-30-2017)
I think you might have Nailed it, as it does sound a bit like a bang from a lead, I'll try and do a Video at night.
She was running great before I went and put the mechanical fan back.
High OB,
Sounds pretty good to me and certainly not terminal. At the start of the first video maybe a shorting HT lead at the start or an engine that hasn't run for a while (or a fan blade just momentarily kissing something) but second video sounds ok.
As previously said let it run up to temperature keeping a close watch on all the gauges. If that goes ok and oil and water at normal level and uncontaminated then, if you have any further concerns, a compression test would be my next thought.
Good luck,
LeeP
Good luck,
LeeP
#28
High OB,
Good luck,
LeeP
Good luck,
LeeP
That is a massive relief I can tell you, next job is to find which lead is shorting, although it only seems to do that the first time you Start her up.
Received 1,442 Likes
Hey OB . . . reassuring to hear that 2nd clip . . . big relief, because compared to advice thus far, my analysis of the first clip leads me not towards HT, but back to cams, buckets and valves . . . shades of hydraulic tappets / cam followers which have bled down after non-use . . . and which, of course, this engine doesn't have.
On any rebuild done by a lesser mortal (ahem), and based on both your vid clips, I would have diagnosed inadequately oiled buckets on assembly which have temporarily stuck at start-up . . . but with stuck valve(s) not saying "hello" to piston(s), just getting slapped by too wide clearances. A few rotations, a little heat, and much needed lubrication, and the buckets are now fully following the cam lobes.
By going back and forth between clips, and despite my deafness in one ear, am I the only one who can still hear (or imagine?) some residual tappet noise, even throughout the second clip? Not for a minute do I suggest an immediate re-strip to check valve clearances, nor do I suspect an admittedly far easier compression test will now add much. Better to focus on getting her up and on the road, putting miles on, then re-torque heads and re-check valve clearances at 1,000.
You have come so far, and I sense the Jaguar gods are still smiling.
Cheers and best wishes mate,
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Ken
#30
Hi Ken
Nothing wrong with your hearing, as I also detect some Tappet noise as well, although very feint in that Second Clip.
So while I'm not completely out of the wood just yet, things may not be quite as bad as I feared, although of course I don't want to speak too soon.
She probably needs a bit of a run but one or two other jobs to tidy up first.
She also recently had an Oil and Filter Change a Month ago.
But that 'Tap Tap' noise on Start Up had me worried and thinking 'dropped valve'
Alex
Alex
orangeblossom (05-01-2017)
#32
OB lives to fight the good fight, but you are wise to pay homage to the gods and tread softly.
Ken
#33
With Ken also.
Some tappet noise on a V12 that has sat for 16 years, and only idled basically since raised from sleep, is a GOOD thing.
Get the MOT, drive it to Greg's and back, and put the lead boots on, Take a dose of "brave pills", then revisit the noises.
All my V12's were tappetty after too much suburban use, so any excuse for a road trip, and there is nothing as exhilarating as a V12 at 6000rpm on the highway.
That engine is fine, and we will discuss it more when it tops 500K miles.
cat_as_trophy (05-01-2017),
#34
from what i could see and hear its that bloody fan. which restaurant?
just looked again and unless my eyes and ears are fooling me (very possible) every time there is a tap noise the fan seems to pause slightly as if it is clumping something. Have a look for "witness" marks on the fan or surrounding sticky out bits (technical term)
after all the heartache its caused you over the past few days i think she needs a damn good thrashing. dont worry about an mot as you will be going too fast for the "old bill" to catch you
The following 2 users liked this post by leo newbiggin:
Grant Francis (05-01-2017),
#35
OB the second video the engine sounder strong, I did hear the noise in the first but seems too have gone away quick. at first it sounded a bit like an exhaust leak but it stopped, the other as Daim said, sounded like in around the fan. but looks like the Jaguar gods have blessed you.
It feels like I'm being punished, for Something I haven't done (Yet!) which is basically to drive the blinking thing.
So big lesson out there for everyone, unless you want to end up replacing all the Calipers, renewing all the Brake Hoses, replacing all the Brake
Pads, Buying 4 New Tyres.
Then by being Scared to death when the Engine Starts to make Strange Noises
![Icon Cold](https://www.jaguarforums.com/forum/images/smilies/icon_cold.gif)
I could go on but I'm sure you have got the idea...........
And then you wonder why it isn't working!
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
#36
#37
Hi Grant
Nice idea but I may have to Win the Lottery on Roll over Week just to pay for the Petrol!
Had a little Trip out on Saturday, where we were promised a nice Sunny day and just for a change this time they got it right!
And that cost me £45 in just Petrol alone!
Which was in my Grey XJS
That still needs a name, although I'm suspecting 'Juicy Lucy' is already taken.
But in any event after your advice as well as that from everyone else, I am now feeling much more Optimistic.
So Cheers everyone and Thanks for all your help and reassurance.
Although the Saga Continues, as one of my Brake Pipes is Leaking!
The following 2 users liked this post by orangeblossom:
#38
It wasn't the Fan, as I took my time in lining that up just right.
And will try and get a booking at a super dooper restaurant as soon as the Bank Hols are over.
#39
#40
