Cigar Lighter
Cigar Lighter
I have a 1990 XJS V12 with a cigar lighter that does not worr but I do have a working replacement. I have looked around a lot but can't find out how to replace the unit. Does anyone know how to do this or could point me to the right information. I would rather not remove the full "ski slope" center console if I don't have to do that. Isit a relatively easy job or should I send it out to a restoration shop or Jag dealer?
Its a simple swap. Take care releasing the four tabs underneath the plastic surround (use plastic trim removers - slide them between the ski slope and surround to slightly push the tab back and 'pop the trim piece up and out) go slow and once removed you can swap out the lighter, I assume you've checked fuses etc?
New Cigar Lighter or Better Idea
I took out my cigar lighter and replaced it with a dual USB Port that fit into the same bracket. It's easy & cheap using the Blue Sea Systems Dual USB Charger Socket .
FS[SouthEast]: V12 1986 XJ-S parts
Jose
12-23-2015 08:00 AM
FS[SouthEast]: Very Pretty Triple Black XJS V12
MEC
12-20-2015 12:57 PM
