Cigar Lighter: no power?
I bought one of those mini voltage gauges designed to be plugged in the cigar lighter socket (so that I can monitor the voltage).
Well, I started the car and plugged it in but it did not show anything. (Not because the gauge is bad -- I tested in my Jeep it works.)
I cleaned contacts to remove some rust -- still no go.
Anybody had similar issues with cigar lighter socket not producing any juice?
a bad ground? power goes in thru the big purple wire that seems to sort of twist onto the single post on the bottom of the cigarette lighter. The black wire spade clip on the side is the ground. Maybe you can trace it out and see if the ground connection is dirty/rusty
I am trying to figure out where the cigarette lighter light black wire with single connector plugs into. I don't see any spare wire connectors in there. There is a two point white clip but the round connector seems too big for either hole.
v1rok (04-30-2017)
v1rok (04-30-2017)
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Other than that, it is kind of spooky how time after time after time people here appear to know exactly what is wrong with my car based on (what to me seemed like) slightest hints, sight unseen. Un-believable. (And, yes, very spooky.) But I am glad as hell to keep learning from the Jaguar wizards!
Greg in France (05-01-2017)
Received 1,442 Likes
Your little "non problem" also underlines the value of both having, and learning how to use the wiring diagrams & notes specific to your model & year of Jaguar. Use the wiring diagrams to trace all the way from "problem" component (cigar lighter) back to battery . . . noting each fuse and connector along path. The attached notes will locate each fuse; whether connectors are multi-pin or simple in-line bullets, prompting you to check each wire for continuity or short, each fuse for integrity, and each connector for corrosion or disconnection.
Oh . . . and having the support of people like Greg, Grant and others is just like icing on the cake, eh?
Cheers and best wishes,
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Ken
Ken
Hello, my 1996 XJS cigar lighter works, but won't charge my Iphone. I put in multiple phone charges but none seems to work. A mechanic told me he thought all the phone charges I was using were too short to reach the contacts. Has anyone come across this before?
