cilinder head torque '86 5.3 XJS V12 HE
Old 02-26-2013 | 09:34 AM
mopar's Avatar
Default cilinder head torque '86 5.3 XJS V12 HE
I al looking for the cilinder head torque setup, I have new gaskets but do not know what the force is to tighten the bolds.....
Old 02-28-2013 | 09:46 AM
mopar's Avatar
Hard to get info?
Old 02-28-2013 | 10:04 AM
Greg in France's Avatar
Originally Posted by mopar
Hard to get info?
According to my Haynes manual the 7/16ths cylinder head nuts are tightened in three stages:
Stage 1 = 25 Lbf/ft
Stage 2 = 40 Lbf/ft
Stage 3 = 52 Lbf/ft
The 3/8 nuts are tightened at stage 2 and three as follows:
Stage 2 = 20 Lbf/ft
Stage 3 = 28 Lbf/ft
These are for the pre HE engine, and the manual does not quote any different figures for the HE engine, which has a higher CR. Worth checking though as it is an HE you are working on.
Old 03-04-2013 | 07:58 PM
magnoliav12's Avatar
Default Torque
This is from my AllDataDIY manual. The conversion to LBS is at the site listed at the bottom. Also, I attached a pic of the sequence from the manual. This is for the '85 HE
TORQUE FIGURES
Air pump adjuster bolt/locknut 2O - 27 Nm
Banjo connector bolts 12 - 14 Nm
Camshaft sprocket to camshaft 23 - 27 Nm
Camshaft cover 11 Nm
Connecting rod cap nuts 54 - 55.5 Nm
Cylinder head to block (9/16"AF) 36 Nm
Cylinder head to block (11/16 "AF) 70 Nm
Elbow to inlet manifold 12.2 Nm
Engine mounting bracket to crossmember 19 - 24 Nm
Engine mounting tie bolts 34 - 40 Nm
Exhaust down pipe to manifold 30 - 35 Nm
Fan/torquatrol to water pump 23 - 27 Nm
Flywheel bolts 90 Nm
Fuel pipe unions (5/16" dia.) 8.5 - 9.5 Nm
Fuel pipe unions (3/8" dia.) 11 - 13.5 Nm
Fuel pipe unions (1/2" dia.) 27 - 33 Nm
Heat shield to manifold 23 - 27 Nm
Hose clips 2.5 Nm
Inlet manifold to cylinder head (nuts) 23 - 27 Nm
Inlet manifold to cylinder head (bolts) 23 - 27 Nm
Main bearing cap nuts (1/2") 84 Nm
Main bearing cap nuts (3/8") 36.5 - 38 Nm
Oil cooler pipes 54 - 50 Nm
PAS pump to mounting bracket 50 Nm
Propeller shaft bolts 36.5 - 43 Nm
Rear engine mounting peg 34 - 4O Nm
Rear engine mounting rubbers 36 - 43 Nm
Rear engine mounting to body (5/16 bolt) 19 - 24 Nm
Rear engine mounting to body (3/8 bolt) 36 - 43 Nm
Sandwich plate to block 16.5 - 21 Nm
Silencer to compressor union 34 Nm
Sump drain plug 15 - 18 Nm
Sump set screws 16 - 20 Nm
Torque converter bolts 55 - 62 Nm
Thermostat housing to cylinder head 23 - 27 Nm
Converting Nm to LBS:
Torque Conversion
Old 03-05-2013 | 05:36 AM
mopar's Avatar
Thanks for the info, now I can do the work correct, hope te solve te oil leak with the new seals and gaskets.
aholbro1
08-05-2021 06:02 AM
vinny jones
10-05-2015 08:20 AM
DrTripp
09-14-2015 08:58 PM
1100me
09-07-2015 07:26 AM
d a
09-03-2015 03:34 AM
Quick Reply: cilinder head torque '86 5.3 XJS V12 HE
