Code P1777
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
On further research I found that Jag issued a TSB stating that this code on 95s was indicative of a TCM failure.That explained the "limp mode" problem. The trans wouldnt shift. Stuck in 3rd. They recommend replacement with a 2400 AH 001 model TCM. I was able to find an 004 unit (XJ6) cheap and tried it.
IT WORKED! Shifts like a dream...
mirisisa (07-01-2013)
Hi!
I'm having the same problem with my 1995 XJS convertible. Just went into limp mode last night when I started it up. Ran the codes this morning and I got a P1777.
For you the problem was the TCM? Where did you find a replacement? Your help would be greatly appreciated!!
Thanks!!
Thanks!!
philwarner
25
06-26-2021 05:43 AM
