cold air intake
cat_as_trophy (11-17-2017)
Grant Francis (11-16-2017)
Here is what another member did, I like this one.
https://www.jaguarforums.com/forum/x...es-v12-136567/
Why not do the FL 6.0l intake from the top of the radiator? The air there is cold (except in a jam but that isn't where you'll be needing it).
Basically you need either a 6 cylinder bonnet or a FL one (they are the same). The front radiator crossmember, some piping and the brackets on top of the radiator. Basically it. Con ect to intakes and é voila! A factory COI.
Received 1,442 Likes
Grant Francis (11-18-2017)
BTW when you do add CAI, do not take the air from inside the wheel arch, this is a low pressure area and will do more harm, I did a fair bit of testing when I added a CAI to my WRX years ago and power on the dyno dropped when I added the CAI because I plumbed it so it sucked from the wheel arch, after adding another pipe forward to the lower part of the air dam power went up again.
You need a high pressure area, behind the headlight, over the radiator or beside the radiator.
Not now. The intake is in the LH opening of the front skirt that I thought?????? was a brake air intake, NOPE, just air into a "dumb" aperture on each side.
Simple 60mm air duct I found at an a/con supplier, and fed it through to the air box, after, I removed the silly factory intake snorkel.
All of 20 minutes work.
![cold air intake-s-cold-air-3.jpg](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/205845d1511089756t-cold-air-intake-s-cold-air-3.jpg)
AND, the scratches are now GONE, oops.
So did both my S Types.
Attachment 205845
Attachment 205845
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
