Cold Start Issue
Old 12-16-2021, 09:20 AM
Vinman12's Avatar
Default Inherited a 1976 XJS, cranks but no start
It's a great car,
white, tan interior, great condition with no rot, nice interior other then headliner, 55000 miles, cranks and will fire with a shot in the breather, good fuel pressure, not getting fuel to the cylinders.
Mkii250 (12-24-2021)
Old 12-16-2021, 09:44 AM
jal1234's Avatar
With the ignition on, slowly open the throttles by hand in the engine compartment, and listen for the injectors to click. If you don't hear clicking, I'd suspect stuck injectors from sitting. This video, a few minutes in, shows a trick to get stuck injectors to unstick. Otherwise, they'd have to becremoved and sent out for cleaning.
You can also check for injector pulse with a noid light or a scope on the injector connectors.
Old 12-16-2021, 09:53 AM
Vinman12's Avatar
https://youtu.be/nMaOtaaI4Yk
i will watch the video, i did turn the key on and work the throttle under the hood, no clicking at all..i'll continue to give it a try, but i think it may be hitting the old "for sale" ads soon..
Old 12-16-2021, 09:54 AM
Vinman12's Avatar
no clicking, ill watch the video and go from there ,
Old 12-16-2021, 03:49 PM
ptjs1's Avatar
Received 3,156 Likes on 2,078 Posts
Vinman12,
76 XJ-S? Super-rare and becoming worth big money (at least in other parts of the world!).
Don't sell it! Get it running, recommission it then either drive it...or sell it for big money!
Paul
The following 3 users liked this post by ptjs1:
Grant Francis (12-17-2021), Greg in France (12-18-2021), orangeblossom (12-16-2021)
Old 12-16-2021, 03:55 PM
Vinman12's Avatar
Default Making progree
I did get 11 injectors to fire, just one stuck a d it does attempt to start but I believe the plugs are fouled from all the cranking, I'll keep tinkering with it in my spare time but I ha e listed it for sale, too many other things to do and may be moving so it's up on the chopping block
Old 12-16-2021, 05:26 PM
OldCoastie's Avatar
With those headlights and bumper isn't this a 96 vs 76?
Old 12-16-2021, 05:34 PM
jal1234's Avatar
No, early XJS bumpers looked like that in the states. It's apparently been fitted with Euro headlights.
Jon
Old 12-16-2021, 05:44 PM
OldCoastie's Avatar
Thanks for the clarification.
Old 12-17-2021, 01:50 PM
Vinman12's Avatar
its a 76, came with the bumpers and headlights as new, located in phila pa in the usa.
Old 12-23-2021, 06:25 PM
Vinman12's Avatar
Default 76 xjs not firing up, sat for many years
76 xjs not firing up but fires with a shot of fluid but not staying running,, seems to be getting fuel pressure well at the filter under the hood , and working the throttle from under the hood, can here clicking, i did run a jumper to each injector indepenantly and each is free and clicking, so they are not stuck,, whats next ????
Old 12-23-2021, 06:31 PM
Vinman12's Avatar
i did manage to to get the injectors free, but still does not seem to be getting fuel, good pressure at the fuel filter under the hood and will attempt to fire for a few seconds on starter fluid, so i know its getting spark. its worth keeping at it because it is a rot free car with still a good original finish and pretty nice interior and only 50,000 miles on the v12.
Old 12-23-2021, 07:47 PM
Received 10,566 Likes on 6,978 Posts
Bugga.
The XJS Section has a lot of info, stickies etc at the top. Granted, most is the HE beast, yours be Pre HE and has its own little oddities that mainly us Senior people remember.
Just because the Injectors be clicking does NOT mean they are opening the needle to pass the Bang Juice.
When operating the capstan with the Ign ON, SLOWLY, you shoud get 9 clicks as the internal wiper passes the segments. It appears you are getting something?
I have taken a SMALL Hammer (down here called a Tack Hammer), and GENTLY, tap, tap, tap each injector as you SLOWLY work that capstan. Has worked 100% of the time for me on many a PreHE.
I am assuming the fuel lines have been flushed with clean fuel, and the filter replaced??
Injector pulse whilst cranking is a "special thing" on these engines, and I can walk you through the testing/sorting/fixing of that if need be.
Oh,forgot.
When operating that capstan for the "clicks", the system only fires the last 6 Injectors that were operated prior to shutdown. How a purely Analogue system knows this, I simply dont know, and it really makes little difference, it is what it is.
Old 12-23-2021, 08:56 PM
Vinman12's Avatar
yep, its a tack hammer up here too, i will give that a try this weekend and see if that does it, also a friend of mine has what he called "a noid light kit" so i can confirm they are getting a pulse, thanks again, i'll update early next week, have a Merry Christmas"
Grant Francis (12-23-2021)
Old 12-23-2021, 09:57 PM
OK.
if you find no pulse, PLEASE resist pulling things apart, a lot of those things are HUGE $ if you find them, most a NLA.
That pulse system is simple if a systematic approach is followed.
Let me know, maybe I write a PDF, might be smart for the archives for 40 years time.
Old 12-25-2021, 09:13 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Hell yeah it is!!!
Pull what plugs you can and have a look at em...? A few fouled plugs is no good.
Have you had a look at what's going on in the distributor cap?
Where is the loom to the injectors? Down in the valley?
Can you post a picture (if you haven't already) of the engine bay,,, getting as much of the engine in the snap(s) as you can?
If you are not worried about AC at this point, you can just cut the AC belt to remove,,, undo the AC lines and remove the HUGE A6 compressor,,, and then the cruise control bellows and get all that out of the way temporarily... That's just me. Will make this part of your process much much less painful. A smaller and more modern AC compressor might be in your future anyways - unless someone has already updated it...?
You'll get this thing going, no doubt.
Old 12-25-2021, 05:35 PM
GGG is offline
Received 16,868 Likes on 12,186 Posts
It's a great car ......
I've moved your other thread on the same topic from General Tech Help forum and merged it with this one to keep all relevant discussion in one place.
Grant Francis (12-26-2021)
Old 12-27-2021, 03:51 PM
Vinman12's Avatar
well, been at it today, found a broken wire from the trigger board harness on my "pre he} 76 xjs, not getting a pulse and spark and fuel pressure, it appears to be that maybe the injectors are clogged, they are free and getting a pulse but still not feeding fuel to the cylinders, it will fire for few secondes on starting fluid, i see tone of injector rebuild kits for 81-91 but dont seem to be able to find a complete kit with hoses,clamps, micro filter and seals for the 76 model, anyone have a sourse for a kit for these older "pre he" models ?? vince, philadelphia pa USA
Old 12-27-2021, 04:46 PM
JayJagJay's Avatar
Someday very soon you will want and need to redo them injectors, there hoses, there seats in the intake and stuff.
When I walked up to my car several of the injectors were clogged and having read here I knew a whole refresh was in my future so, a newbie and new to working on cars, it was a scary but empowering feeling to just grab a set of large wire cutters and go around and cut the hose between the rail and the injector, take it away and then remove the injectors one by one. The injectors are rugged and can be brought back to life. Takes a solvent, soaking, some pressure, a small hammer and a 12v source TAPPED on the leads of the injector. Most folks will take a spare FI plug, plug it into the injector and quickly TAP the wire ends to 12volts... Again,,, only touch the wires super fast to the 12volt source or you could fry the injectors. Short taps.
Later, I bought a set of remain and tested injectors and installed them. By then I had the XJS bug. They are awesome cars to work on! They just are
Old 12-27-2021, 04:54 PM
ptjs1's Avatar
Vince,
See here: If you're not sure of what you need, drop him a line.
Paul
Jaguar - Mr Injector UK
Quick Reply: Cold Start Issue
