Compression Check on a XJS v-12
@Manny
When I got my compression test done my mechanic told me that the absolute values were not all that important, it was the range of values that mattered. (Assuming the car is actually running, which removes the possibility of all cylinders having a problem, which I guess you could get if someone had been messing with the heads, or just rebuilt it badly, or something). He said he had seen cars give quite different absolute results compared to each other, but each had a very small range and was deemed to be good (This was subsequently proven to be the case). Maybe others will chime in with a definitive answer, but I was happy with this explanation and used this data to help make my final decision to buy or not
Received 10,933 Likes
Good that they're even but that sounds awfully low. The service manual shows 200-240psi for the HE engines. I expect the lower end of the spec if the the 11.5:1 engines and the hiigher end for the 12.5:1 engines
This is most likely why your pressures were down. With the throttle closes you wll be getting less than 5.3L of air into each cylinder.
CR is the ratio of volume of air at BDC to TDC in other words how much the engine compresses the air. So a 10:1 CR will compress 6.0l of air ( a 6.0l engine) into 0.6l so if we say we have a combustion chamber volume of 10cc 0.6L and 10cc gives say a pressure of 200psi
If you only fill the cylinder with 3.0L of air when the engine compresses the 3.0L into 0.3L in 10cc the pressure will be 100psi.
Received 6,330 Likes
Warren, you are right but your maths are wrong.
5.3 litres is the displacement for all 12 cylinders.
displacement = Pi/4 x bore squared x stroke x number of cylinders
So the 5.3 will be 0.785 x 81cm sq x 7cm x 12 = 5.34cc
Therfore only 445cc = 0.445 litres of wind in each cylinder.
I realise that the numbers were only to make easy for people to follow
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
