Compression Test Results
Here are the compression test results for my 1994 xjs 2 + 2 w/ 111k miles:
1) 162.5
2) 172.5
3) 172.5
4) 172.5
5) 167.5
6) 167.5
According to the manual I have the compression should be 160-170 for the 4.0 engine and there should be no more than a difference of 10psi. I'm right on the nose with the first cylinder being at 162.5. I did several tests and they all come out the same. Should I be concerned? Is this car worthy of a new paint job?
1) 162.5
2) 172.5
3) 172.5
4) 172.5
5) 167.5
6) 167.5
Did you re-test more than once? and if so I would use the mean of your readings
