compressor wiring help!!
Can someone post pics or give info on the wiring for the a/c compressor??
mines never worked since i got my car and i assumed it just needed freon (parked for 15 years) I tried to put some in the car but it wouldn't take it at all.
So i assumed i had a bent valve and my compressor was kaput. Until recently removing it for my water pump....
NONE of the wires are connected and before they were shoved away where i could no see them. There are some coming off the side and a ground all of which are taped up and cut off . So im just assuming the a/c has to be on to take a charge and maybe I just need to rewire it.
thanks!!!
thanks!!!
upon further investigation i think i have found the culprit. There are plugs on the compressor. There are wires joining the 2 and then 1 seperate coming off just one plug.
For me the seperate one is a green with orange tracer. Then there is a white wire and a blue wire which connect to one point. These both end then i found 2 wires coming from the harness and i see a ghetto ground on the compressor plate.
So im assuming i can properly connect these 2 and it will work. Feedback and pics are still very welcome thank you
scooternva
19
10-27-2015 02:14 PM
Dicque
09-19-2015 12:53 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
