confusing relay action
Today's project involves connecting two standard 40 amp auto relays in series.
It looks like this...
(wire from + power and switch)----relay 1 coil terminals---relay 2 coil terminals...ground.
The idea is is that when the switch is thrown, relay 1 and relay 2 will activate. And indeed, this is what happened when I tested them in the garage.
Took it out for a test drive. On the first activation, the relays both closed. On the second and succeeding attempts, the relays did not close.
Back in the garage. Put a meter on the relay one "input" coil terminal and throw the switch. I get 12 volts, as expected.
Put the meter on the relay one "output" coil terminal...I get 6 volts. What???
Should I have wired these in parallel?
Thanks,
John
1987 XJ-S V12
Thanks,
John
1987 XJ-S V12
Gavin78
10-08-2012 06:04 PM
