Considering a 1986 XJS - Dana differential issue
I'm still undecided as to which XJS I would like tobuy(newer 6.0L V-12 or older style XJS with 5.3L). At any rate, I found a very nice '86 coupe with under 70K miles and clean as new penny both inside and under the bonnet. The only "major service" that has been done to it was a new rear end. Supposedly it had a Dana differential in it that wasnt serviceable, so a rebuilt other type (I dont recall what it was) was installed. Is a differential replacement a common problem? (I know my '94 Vanden Plasstarted leaking at theouter seals when it was about 5 years old.) Should I check anything further prior to purchase with respect to the differential? I found out the shop I was going to use for the pre-purchase inspection is the same shop that redid the differential, as well as some other service (oil change, wiper motor, front rotors). I'm also wondering if I should havethe cartaken to a different Jag place in Portland for inspection for fear of a potential conflict of interest. This isa long distance purchase, so I am at the mercy of the inspection mechanic. Apparently, there are two good ones (maybe three) inPortland, OR - one of which is the one thatdid the repairs.
Thanks for the info. Are there any "typical" problems with a mid-80s XJ-S to be on the lookout for? I have heard of A/C evaporator issues.The evaporator in my '94Vanden Plas had to be replaced as it developed a leak and I hear that several other years had A/C evaporatorissues.This car has theoriginal R-12 system and supposedly it still blows cold. I have a '73 Thunderbird and '65 VW with their original R-12 systems and no issues. I'mof the philosophy "if it ain't broke, don't fix it".
Your posts are a little hard for me to follow, but that might be my fault... I've never heard of a '65 VW with A/C, and I really don't care to.
Salisbury and Dana differential faults are more common than leaking A/C evaporators on XJS. If you find a car with a replaced diff, and it's not noisey, consider it a plus and forget about it.
There is quite a bit of difference between 6.0L cars and mid 80's cars, like major discrepancies in availability and price. If you want a mid 80's 5.3, there is no reason to buy one long-distance. They are everywhere, even nice ones.
ORIGINAL: JagtechOhio
99xk8guy
06-05-2023 06:28 AM
rsa760041
23
09-25-2015 01:33 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
