Convertible maintenance
I've had my convertible for 19 years and the only thing I would suggest is to use a good fabric roof cleaner once a year, and reproof as necessary. I also use a great product called Gummi Pflege on the rubber pieces that abut the windows and windscreen.
Apart from that, the car must be driven at all times with the roof down!! It's just the law!!
Good luck
Paul
Good luck
Paul
The following 3 users liked this post by ptjs1:
15yrs of driving my 93 in Arizona, top up and down, have given ZERO issues from the top operation. Notable related exception is the rear quarter windows which use relays (pink/purple) to tell the windows when the top goes up or down. The relays are seldom the problem when the windows stop operating as designed. The regulators are always the culprit. Because all regulators stop at the same place on the "up" and "down" positions, they created a "dead spot" on the contact. Replacement regulators are pricey, if you can find them. Remove the regulator and try manually moving the gear position to avoid the "dead spot".
Dennis07
08-13-2020 08:40 PM
