Convertible roof handbrake switch
Where did you connect the battery? The hood ECU get power from ignition feed, so the battery should be connected as usual and ignition on and car in park or neutral. Is the module getting a good ground/earth signal on the B/W wire?
Door windows are completely independent of the hood. Up to VIN 156988 there is a power window relay, the relay after that also powers the cigar lighter. The relay should be on the right side behind the undescuttle trim.
The relay is triggered by the ignition switch power, so perhaps you have a faulty ignition switch or power isn't getting to it somehow?
#28
I've had another go this morning. Re connected the battery and switches and the passenger window worked. Went to check for power on the other side and noticed the body shop had the plugs wrong way around. Swapped them and they presto both windows work. Roof still no go. I've checked the micro switch for continuity and it was ok. Checked the roof switch with one of the windows and that was ok. Swapped the wires around on micro switch still nothing. Not sure if I heard a click in the boot or not?? Any suggestions?
Timeisrelative (02-13-2022)
#30
#31
#32
#33
Timeisrelative (02-16-2022)
#34
