Convertible Top Fluid Sensor
Is there a sensor in the convertible top fluid reservoir to tell it when it is out of fluid? I have a leak and am going to refill it to find it, but the motor doesn't run at all at the moment (it used to intermittently work) and I am wondering if it can sense the fluid issue.
No fluid sensor. But I will tell you from experience....with the wrong fluid, i.e. power steering fluid, etc., the viscosity will cause so much draw of amps, that the windows won't work properly, nor will the top go all the way up or down before the time the control unit works will cause the top and or the windows to stop. The correct fluid is so incredibly thin that it seems to pour easier than water if that is possible. Once I flushed my system, put a new seal in the pump, refilled with proper fluid, my top and windows will go fully up, or fully down in 6 seconds flat.
TweeTwee (12-01-2015)
TweeTwee (12-02-2015)
oh if it is you pump leaking you will need to replace the seal in it
try this
try this
TweeTwee (12-03-2015)
sklimii
12-11-2015 07:08 AM
Joe Gandalf
12-04-2015 05:58 PM
