Convertible top replacement
Old 05-05-2016, 07:39 AM
Bruce Vanderwerf's Avatar
Default Convertible top replacement
I have a 1989 xjs and I am going to replace top and headliner ,I need too know if there is a pad that goes in-between the top and headliner if so what can I used or where can I get the pad also it would be a great help if anyone had done this job
Old 05-05-2016, 11:18 AM
Hi Bruce,
If you do some searching here on the forum you will find many post about replacing the top. I did this job a few months ago on my '9o.
I can tell you that the pad is not available from anyone that I could find. I ended up making a new one from a more modern materiel. I will try to find the details and post it here as soon as I can.
Mark
Old 05-05-2016, 01:03 PM
Roger95's Avatar
Hi Bruce, as safari says there is a pad between the top and headliner. You can do most of the job yourself though there are times when an assistant is needed. I replaced the top, headliner and pad on my '95 some years ago. My bride was my assistant and we are still married...
Jonathan-W (05-13-2016)
Old 05-05-2016, 01:30 PM
orangeblossom's Avatar
Received 3,771 Likes on 2,611 Posts
Give these guys a try.
https://www.convertibletopguys.com/c...dt-Conversion-
Old 05-06-2016, 12:20 AM
Hi Bruce,
Take a look at this thread to learn more about replacing the top;
https://www.jaguarforums.com/forum/x...cement-142542/
Mark
Old 05-08-2016, 01:43 PM
xjsrookie's Avatar
Default A Place to Try
Try Paul's Jaguar, (561) 367-0525...
Old 05-08-2016, 07:26 PM
superchargedtr6's Avatar
I had my pad made at a local trim shop for 150.00. There are all kinds of opinions, advice, yet all I can say is get ready for a job. You will in all likelihood find that most, if not ALL of the tabs that hold the pad and the cable that goes through the pad have rusted away. I made new tabs from rigid aluminum yet bendable, and riveted the pieces on. Buy ALL new cables. They will be shot. As a mater of fact, buy two of the rear ones just in case you break one (as I did). There are several more "tricks" to it, but it can be done. It will take two people to get the top around the track at the rear, and I found that a mixture of dishwashing liquid sprayed on the top when placing it, as well as tightening it helps far more than you can imagine. The only thing I look back on in doing "wrong" was not centering the top dead on before spraying the adhesive. You will need a crown stapler, and a box of 1/4" stainless staples
Old 05-13-2016, 02:24 PM
Jonathan-W's Avatar
my pad is some kind of organic material... I also need a new top with in the next 5 years so I will be gleaning this thread....
Old 05-13-2016, 08:01 PM
I reused that "organic" material on mine. I just took the pad to a local trim shop, and they recovered in using a material that so closely resembles the new top, you can hardly know the difference.
Febres
06-30-2016 03:53 PM
Steve Youn
05-26-2016 12:20 AM
jeffn
05-02-2016 08:55 PM
Narda 1
05-02-2016 12:46 PM
xjay8
04-29-2016 07:03 AM
Quick Reply: Convertible top replacement
