Convertible Top Tension Wire
When I purchased my car it had no top. I put a new top on years ago with a DIY tension wire. I finally purchased an OEM tension wire.
I have an issue where it does pull down correctly on the sides. Now that I am replacing the wire I would like to remedy this. I believe they had a cut out in the canvas to keep the wire in place? Can someone check the to pon their xjs and let me know if there is a cut out?
Here is a photo of what Im dealing with (...car is being wet sanded after fresh paint in case your wondering):
![](http://s19.postimg.org/khd0qpj0z/20141207_114223.jpg)
It could be that the "lip" is bent down against the car, not allowing the tension cable to properly tuck the top under it. The tension wire actually passed through the top about there on my 89. If I remember correctly, I had to cut a small slit, and the cable went through the top as it got near its anchor points.
I'm going to try cutting a couple slits in the problem area. I can always go back.
Thanks, I was wondering this when I was doing it and could not find a close up photo.
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
philwarner
09-05-2015 10:05 AM
