coolant leak
Received 10,871 Likes
Well, I'd say it's either the heater core, with the leak comng thru the a/c drains, or one of the heater hoses. Or perhaps the heater valve.
From your description it sounds like a big leak. The heater hoses and valve are not especially easy to see but you should be able to run your hands and finger over them and feel for any wetness. Wait for the engine to cool down a bit![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Hi all,
I was able to take a closer look. The hose that has sprung a leak near in the engine bay is located at the back of the engine. It's a small hose 9/16 or so that tees off of a cross pipe at the back of the engine. It leads down through the fire wall and under the car and seem to connect to a metal tube above the cat converters.
The end in the engine bay was easy to get off but the other end appears to be a bigger challenge.
Any thoughts???
Tony in NM
Any thoughts???
Tony in NM
Cross pipe?
Are you referring to the 1" diameter aluminum pipe that connects to the left and right intake manifolds? If so, that's a vacuum balance tube. It has a small hose attached that runs downward and rearward...clear back to the ECU in the trunk.
It should never have coolant in it.
Cross pipe?
EDIT:
something I found called it an air diverter check valve. Im guessing it was just dirt and gunk and not rust from coolant.
probably heater hoses then
OK, I found the leak. It was, in fact, a a heater hose between the valve and firewall. As with all things Jaguar, it was a PIA to get to, get off and the new one put on. I drove the XJS around and no leaks. To top that off, the cooling system seems to be keep the engine temp under control.
Thanks for everyone's help,
Tony
Tony
OkieTim
09-08-2015 04:48 PM
