Coolant Recomendation
Old 08-22-2017, 08:55 PM
Thorsen's Avatar
Received 1,572 Likes on 677 Posts
Default Coolant Recomendation
I just picked up a 1996 XJS 4.0 and am catching up on maintenance and repairs. What is the consensus for the best antifreeze to use in the AJ16 engine? It looks like the green stuff in there but I am partial to Zerex G05 in my older cars. Just wanted to poll the group and see if there are any thoughts.
Old 08-23-2017, 04:39 AM
roman_mg's Avatar
Hi Thorsen.
Maybe it is solution. I have no problem with overheating of coolant (see spec.). And when is coolant system all right, it is lifetime.
https://www.evanscoolant.com/vehicle.../classic-cars/
Old 08-23-2017, 10:28 AM
Greg in France's Avatar
Received 9,413 Likes on 5,516 Posts
Worth a search on the XJS forum concerning waterless coolant. A lot of us, me included think it is a very bad idea.
Old 08-23-2017, 11:37 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
After having issues with coolant crystalising in the engine, I am going "universal". My XJ8 has ran it now for the last 2.5 years and has no worry. No problems with mixing and matching the fluid. No flushing required. And the universal stuff is cheap as hell... Prestone from Honeywell.
That is what my XJ-S will be getting too.
People most commonly choose their fluid upon colour, which is the biggest "brainfart" you can do. The problem being: the colours aren't identical throughout the market. And they change randomly. My old C30 came with yellow coolant. Which was replaced with red stuff later and then again with blue stuff which turned brown in the end.
You need to know WHAT the fluid was in order to know what you need to top it up with. WHAT means what the chemical base is. Silicone based? Glycerene based? ...
