Coolant Temp Gauge
Coolant Temp Gauge
Jaguar XJS V12 1989. The temp gauge on the instrument panel indicates the engine is running cool. The needle is half way between cold and normal. This just happened about two weeks ago. Previously the needle was dead center on normal. The engine runs just fine. Does this mean the sensor is bad and should be replaced? If so, what is the part number I need to get? Any help is greatly appreciated
